99 durango obd2 port dont work?
Old Oct 19, 2009 | 09:52 PM
gtomanforlife's Avatar
gtomanforlife
Default 99 durango obd2 port dont work?
all so the radio is out all dome light out fues or good what could it be?
Old Oct 19, 2009 | 10:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
The IOD fuse is for the dome lites, and radio. If the IOD fuse is good which is in the PDC box. Then check the fuses in the fuse panel. Ck the fuse with a 12v test lite, just looking at the fuse will not show you if its good.
Old Oct 19, 2009 | 10:19 PM
gtomanforlife
what is iod fues and ware is iod box i was told that obd2 port runs on cig fues
Old Oct 20, 2009 | 12:46 AM
master tech
Go under the hood and find the black box,thats the PDC. And ck the cover for IOD fuse.
Old Oct 20, 2009 | 02:31 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
IOD = ignition off draw
Old Oct 20, 2009 | 03:00 PM
gtomanforlife
every thing checkd good still no radio dome lights or obd2 port is there anything els to check
Old Oct 20, 2009 | 08:16 PM
master tech
You have an open circuit to the radio and dome lites. Then you may need to take it to a repair shop.Because i don't know if you have the tools to ck an open circuit.
Old Oct 20, 2009 | 09:10 PM
gtomanforlife
ok fix the rado and dome light problem now i have a new one lol trans slips into 3rd gear
Old Oct 20, 2009 | 10:43 PM
hydrashocker's Avatar
hydrashocker
How did you fix it?
