TCM Location 2001 Durango SLT 4WD
Old Oct 27, 2009 | 03:38 AM
racecar7@cox.net's Avatar
racecar7@cox.net
Default TCM Location 2001 Durango SLT 4WD
Does anyone know the location of the TCM for a 2001 Dodge Durango SLT 4WD? Also, what is the approximate cost for a repalcement unit?
Old Oct 27, 2009 | 08:59 AM
IndyDurango's Avatar
IndyDurango
Right next to the radiator in the gap on the passengers side. It has a large heat sink on it.
IndyDurango
Old Oct 27, 2009 | 11:53 AM
hydrashocker's Avatar
hydrashocker
Not sure on the cost but check E-bay. You are talking about the Transmission Control Module aren't you?
Old Oct 27, 2009 | 07:52 PM
racecar7@cox.net
Yes, the transmission control module.
Old Jan 19, 2016 | 03:43 PM
Steamboat2003's Avatar
Steamboat2003
Default Best place to buy
Best place I found was online at www.acrautos.com. $169.00 with lifetime warranty!
Old Mar 4, 2016 | 02:19 PM
Ma6tk8sh1tek's Avatar
Ma6tk8sh1tek
Default What do you think about a salvaged TCM (transmission control module)
I found one at a reputable salvage yard for 90 bucks. Does it need any programming or adjustment to the transmission after installing it? I'm getting a P0700 (internal TCM) code and having shift issues on the upshift from 2nd to 3rd gear...thought I'd start with replacing the TCM due to its easy access location. Any suggestions or comments?
Old Mar 6, 2019 | 04:37 PM
Austin Decker's Avatar
Austin Decker
did replacing the tcm fix the problem?
Old Mar 7, 2019 | 09:44 PM
volaredon's Avatar
volaredon
you must have a 4.7. a 5.9 won't have one.
