Head lights help
Old Nov 25, 2009 | 01:12 AM
  #21
IndyDurango's Avatar
IndyDurango
1 piece are real PITAs indeed to install. SUX!
IndyD
Old Nov 25, 2009 | 09:10 AM
  #22
Dans01Durango's Avatar
Dans01Durango
Originally Posted by shrpshtr325
me too, much nicer to look at (when its on the right person)
LOL! You got that right, shrp!
Old Nov 25, 2009 | 09:20 AM
  #23
Dans01Durango
Originally Posted by hydrashocker
I didn't know they were a PITA to do?..... I like the look and was thinking about going to it.
Yes they are a PITA to get on. The two-pieces can be taken off with a torx drive for the corner lights and a 10mm(?) socket to get the three bolts that hold each one in place. The bolts are not that easy to get to in the first place especially the upper inside ones, I needed the six inch and three inch extensions for my ratchet set. Then there's that flex-type push-in connector for the upper outside hole. You have to be careful with that one cause if you use too much force, you broke a headlight housing. I used a flathead to wiggle them loose. I don't know how anyone will be able to install a one-piece w/o damn near taking off the bumber to access the bolts behind the one-piece. Has anyone done a write-up? I would love to see how it's done.
Old Nov 25, 2009 | 01:10 PM
  #24
hydrashocker's Avatar
hydrashocker
The bumper is only 4 bolts and is EASY to remove, at least on mine?
Old Nov 25, 2009 | 08:38 PM
  #25
Dans01Durango
IDK about my bumper. Probably the same 4 bolts. Don't you use them to adjust the bumper height as well? Anyone done the one-piece headlights???
Old Nov 27, 2009 | 10:25 PM
  #26
hydrashocker
They have other adjustment slot holes in them to do a little adjusting.
