Transmission Issues
Old Dec 14, 2009 | 12:20 PM
trw1957's Avatar
trw1957
Default Transmission Issues
2000 dodge Durango The Transmission won't shift after truck warms up! It shifts fine when it's cold. Took it to a transmission shop and they say take it to an electric shop can't afford to keep doing this! Any help out there?
Old Dec 15, 2009 | 12:33 AM
hydrashocker's Avatar
hydrashocker
What motor? 4X4? Mileage?
We need any info you can give us!
Old Dec 15, 2009 | 08:25 AM
trw1957's Avatar
trw1957
5.9------1240000-------4x4
Old Dec 15, 2009 | 08:30 AM
trw1957's Avatar
trw1957
The codes were 753 trans relay i replaced it and code 443 and replaced it and disconnected the battery and the codes are still there!
Old Dec 15, 2009 | 08:44 AM
Dans01Durango's Avatar
Dans01Durango
Did you do the discon batt. and turn the key to on and step on the brake for 15 sec.? I think there's another way you need to clear the trans codes. Maybe yo need someone with a scan tool to clear them, like a snap on shop scanner. Maybe I'm wrong. HTH.
Old Dec 15, 2009 | 10:11 AM
trw1957's Avatar
trw1957
but it also didn't fix my problem it still won't shift right
Old Dec 16, 2009 | 12:05 AM
hydrashocker
Could be the temp sensor or governor sensor.
Old Dec 16, 2009 | 12:32 AM
jaimeskota's Avatar
jaimeskota
Default check
check out the guy posting 46re trans problems i kinda told him my problm it might be usefull to u
Old Dec 16, 2009 | 12:40 AM
master tech's Avatar
master tech
Site Moderator & Tech
P0753 is the 3/4 shift solenoid relay circuit, and P0443 is the evap purge solenoid circuit. If you need the PDF file for these codes i do have them.
Old Dec 16, 2009 | 07:07 AM
trw1957's Avatar
trw1957
I got the codes cleared and before I could leave the parking lot the light came back on and code 753 the trans relay came back on there could the one I got be bad? yes please send me what you have I need all the help i can get. It runs so good like nothing could be wrong but it won't shift gears.
