Trans relearn and sludge
Old Dec 21, 2009 | 10:10 PM
  #21
hydrashocker's Avatar
hydrashocker
+1 Sharps........LOL
Old Dec 22, 2009 | 11:26 AM
  #22
smokersteve's Avatar
smokersteve
Originally Posted by shrpshtr325
go to the dealer, but print out the tsb before you go and take it with you, then you will have the part numbers ect
Thank you sharp
Old Dec 22, 2009 | 12:03 PM
  #23
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
np man thats what we're here for
Old Dec 22, 2009 | 12:07 PM
  #24
Dans01Durango's Avatar
Dans01Durango
Originally Posted by IndyDurango
Here are a few snot photos of the snot (NOTE: not Sludge!) problem on the earlier 4.7s and the TSB to fix it.
Service Bulletin Number: 090100A
CUSTOMER MAY COMPLAIN OF AN OIL EMULSION ACCUMULATION INSIDE THE ENGINE OIL FILL HOUSING
Need to install the following 2 parts
53032126AA Baffle, Oil Fill Housing
53032389AD Cap, Oil Fill Housing
Recommend replacement of the PCV valve as well.
Happy to help,
IndyDurango
Is it just me or does anyone else want some chocolate mousse?
Old Dec 22, 2009 | 12:14 PM
  #25
shrpshtr325
THE ULTI-MOD
hmmm mine has NEVER been that bad, thank god, but im sure that would scare me to open the oil cap and see that much in there
Old Dec 22, 2009 | 12:18 PM
  #26
smokersteve
I just had a lil bit and thin black coating everywhere else
Old Dec 22, 2009 | 12:20 PM
  #27
Dans01Durango
Actually, I have the thin black coating as well. No foam though cause I have the baffle.
Old Dec 23, 2009 | 10:22 AM
  #28
bjamick's Avatar
bjamick
You guys must make some short trips or live in extremely cold temps. Mine doesn't have anything like that. It does however have the lil black coat.
Old Dec 23, 2009 | 10:42 PM
  #29
IndyDurango's Avatar
IndyDurango
Errrr? Yours most likely just has the fix already applied to it to keep this from happening. Once the TSB was released as the fix for older 4.7s, they integrated the fix in to future production runs. Doubtful anyone would see a 2009 for example with that type of emulsification.
IndyDurango
Old Dec 25, 2009 | 01:48 AM
  #30
shrpshtr325
THE ULTI-MOD
mine came with the fix in it, and i dont get it anywhere near as bad as thos pictures show, just a very little bit on top of the baffle
