Trans relearn and sludge
Old Dec 29, 2009 | 10:42 AM
  #31
bluedsteel's Avatar
bluedsteel
Originally Posted by IndyDurango
Errrr? Yours most likely just has the fix already applied to it to keep this from happening. Once the TSB was released as the fix for older 4.7s, they integrated the fix in to future production runs. Doubtful anyone would see a 2009 for example with that type of emulsification.
IndyDurango
My 2008 4.7 has the oil fill and pcv valve in the valve cover. I have never seen anything on the cap with that design.
Old Dec 29, 2009 | 11:55 AM
  #32
hydrashocker's Avatar
hydrashocker
Thats because you have a 2008 Durango which is different then the 2000-2002 that the problem lie. These are two completely different puppies. You D had the problem taken care of and is a complete different design.
Old Dec 30, 2009 | 09:55 AM
  #33
bluedsteel's Avatar
bluedsteel
That design change was a major factor, that and the hp increase, in choosing that vehicle over a previous year.
Old Dec 30, 2009 | 08:51 PM
  #34
02 4.7 Durango's Avatar
02 4.7 Durango
Default 02 durango slt+ 4x4
Okay i see alot of different oil weights what should i use in my truck i currewntly use valvoline synthetic 5 w 20
Old Dec 30, 2009 | 10:15 PM
  #35
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check your owners manual, whatever that says is what you use i think its 5w30, but im not 100% sure i have it written down in the back of my book for when i go to buy oil
Old Jan 7, 2010 | 10:55 AM
  #36
smokersteve's Avatar
smokersteve
My manual states 5W-30 or 10W-30.
Old Jan 7, 2010 | 11:23 AM
  #37
shrpshtr325
THE ULTI-MOD
and it should be broken down by temperature range, use the one which covers the range of temperatures that closest fits the area you live in
Old Jan 7, 2010 | 11:45 AM
  #38
smokersteve
Yes I agree. I put 10W-40 before I knew that It should be 10W-30
Old Jan 7, 2010 | 01:50 PM
  #39
Dans01Durango's Avatar
Dans01Durango
Mobil One fully synthetic 10w30 for me.
Old Jan 8, 2010 | 12:14 AM
  #40
hydrashocker
It needs to be 10W-30 or for very cold environments 5W-30. But if you use Fully Synthetics 10W-30.
5W-20????? Where did you get the information to run that???????
