question about squeeks!
#31
not sure if they are different, ill measure em for ya first thing tomorrow morning (ok more like 900 am when i FIRST wake up
) i dont see any reason for dodge to have changed them i would expect the different sizes to be a front/back difference, but im not sure on this(i THINK there should be a sway bar on the back too)
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
#32
#33
ok i just measured mine 1.482 at the outside bushing and 1.497 at the inside bushing
keep in mind that these numbers could be a little high due to the fact that i washed the truck yesterday AND It seems to have rained last night so there IS ice on the sway bar
so i would say the 1.40 or 1.30 would be correct size (not sure which you said, but either way 100 thousandths isnt a whole lot)
#34
#36
The one that's has the flat surface goes to the frame mount. 1.4" is what you need as I said earlier.
http://www.napaonline.com/Search/Det...+50022+2022007
![](http://partimages.genpt.com/partimages/286140.jpg)
And this on to the outside:
![](http://partimages.genpt.com/partimages/433149.jpg)
#38
I have never had so much trouble with bushings before. first off how do you remove the upper bolt of the inside bushings? do i unscrew the nut? or the bolt?
And the outside bushings! how are you supposed to remove them? the bars are kind of under pressure so when i take the bolts off the bar is pushing the bushing against the control arm(A arm)??
When i replace the bushings should i just take the whole sway bar off? it seems like that would be a lot easier. Plus the old stock bushings dont have a slit in the rubber so i will need to slide them off i wont be able to just pull them off.
