what should oil pressure read during normal acceleration?
Old Jan 19, 2010 | 02:37 PM
jkichline's Avatar
jkichline
Default what should oil pressure read during normal acceleration?
Today my wife called me and said the oil pressure gauge was reading really high but not pegged. I'm going to check it out tonight and see exactly where it is. I'm hoping I don't have some sort of restriction going on. See said she didn't hear any engine noise at all
Old Jan 19, 2010 | 03:15 PM
MAGIC84's Avatar
MAGIC84
FROM HAYNES MANUAL
CHAPTER 2 PAGE 2B-2
OIL PUMP
MIN PRESSURE AT CURB IDLE 6 PSI
OPEARTING PRESSURE 30-80 PSI AT 3000 RPM
Hope this is a good starting point.
Old Jan 19, 2010 | 04:10 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
mine fluctuates, as long as it stays between the two hash marks i wouldnt worry about it, mine fluctuates between them based on engine speed temperature ect ect
Old Jan 19, 2010 | 10:35 PM
jaz27's Avatar
jaz27
yeah my oil gague moves from the lowest mark when in idle to the highest when driving. Dont know what it is but no problems so far.
additional note, my durango was sitting for about six months w/o moving outside in Oregon weather. I dont know if that may be part of the issue.
Old Jan 20, 2010 | 12:38 AM
hydrashocker's Avatar
hydrashocker
If you just had the oil changed they could have put 10W-40 instead of 10W-30 in it and that can do it.
Old Jan 20, 2010 | 12:40 AM
hydrashocker
In your case change the oil with 10W-30 is you haven't done that already.
Old Jan 20, 2010 | 06:57 AM
jkichline's Avatar
jkichline
Thanks for all the replies. It turns out that she noticed its running slightly higher. It's well within the two lines and no where near the 110psi mark. It's pretty impressive that she noticed such a small change. I looked at it pretty close last night and it does seem to be acting a little differently but I don't think I ever would have noticed. I did recently change the oil and I'm certain that I used 10W-30. I checked the oil level and it's just slightly over the full line so maybe that has something to do with the slight pressure change. I would say we're well within the 30-80psi range. Thanks Magic84.
There's a lot of things I need to do to this car. I don't want "replacing the engine" to be one of them!
Old Jan 20, 2010 | 03:17 PM
MAGIC84's Avatar
MAGIC84
[Quote=Jkichline... I would say we're well within the 30-80psi range. Thanks Magic84.
[/quote]
I dont get all the credit, Some of the credit goes to the mechanics, photographers and technical editors at Haynes, I just know how to read and transcribe.
