Is it worth tuning the 5.9 RT Engine?
Got my 2001 RT yesterday
I'm already wondering if the following actually produce any gains
Cold Air Intake System (I like the Keystone Ram Air/Shaker system)
Throttle Body Spacer
Performance Chip (but what stage)
Headers (This is where you usually see the gains)
Exhaust (it seems the stock one is good enough)
Probably about $1000 there
What would the total power gain be for shelling out all that?
Build your own RAM air intake vs aftermarket cold air intake for cheap.
Throttle body spacer - makes a good paper weight (get a bigger throttle body)
Performance Chip - Termporary gain and then useless as PCM relearns and adjust to compensate for chip. (You need a programmer to make changes permanent or get a custom programmed pcm)
Headers and exhaust - Great if you have money budgeted for this.
$1000 you think? Problaby so.
custom ram air intake - $15
Programmer - $400
bigger throttle body $225 (fastman)
Headers and mufflers - $300 and up.
Power gain out of all this? Yes. But doubt you will see butt kicking slamming back to seat power.
I estimate at most realistically around 20-30 HP if you do ALL of this upgrade.
For butt kicking slamming back to seat power, you will have to do some mechanical upgrades to the engine itself. Heads, intake manifold, etc....
Simplest super horsepower upgrade for the money is to get a supercharger setup.
Programmer - $400
Indy Durango..............
Wow, your psychic
Thanks guys for the advice. I did read loads of other posts including those "tornado" fin things you put inside the air inlet
but
I couldn't see anything specific for the RT.
Being RT I wasn't sure if the engine was slightly tuned from the factory so I had to ask just incase some stuff was already there as OEM
Wow, your psychic
but
Na...not psychic, just read about you and the D for sale on the DOC. The seller joined there to post up a for sale thread on your rig. Good buy!!
http://www.durangoclub.com/forum/viewtopic.php?t=12033
Nice LOW miles. Lots of truck left in your 'new' R/T.
Your R/T is all marketing. Same specs as my SLT+. On the DOC, I have a side by side compare of actual build sheets showing the cosmetic differences. What rear end pumpkin you have? Pic? Always a point of debate on R/Ts
IndyD
IndyD
Trending Topics
