check engine light
Old Feb 19, 2010 | 08:19 AM
kingkong72's Avatar
kingkong72
Default check engine light
my check engine light came on the other day so i hooked up the scanner and it said p0304 P0307 and P0300 which are misfires on the cylinders. what in the world is the problem i recently changed spark plugs and the coil packs a month ago so what could be causing it to misfire
Old Feb 19, 2010 | 11:05 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
try a different (preferably brand name) gas, the station you got it from last time could have had some bad gas, or you could have dirty fuel injectors, you can run seafoam through the tank to help with that
Old Feb 19, 2010 | 11:22 AM
kingkong72's Avatar
kingkong72
they are brand new injectors so im going to get dry gas and fuel injector cleaner
Old Feb 19, 2010 | 10:02 PM
kingkong72's Avatar
kingkong72
tried all that still acting up
Old Feb 19, 2010 | 10:41 PM
master tech's Avatar
master tech
Site Moderator & Tech
If you go to the first page, where it shows 1st and 2nd gen durango's. 17th line down i posted on how to perform three types of compression test. Do read it, it may help.
Old Feb 19, 2010 | 11:51 PM
hydrashocker's Avatar
hydrashocker
What plugs are you using and did you gap em?
Old Feb 22, 2010 | 06:52 AM
kingkong72's Avatar
kingkong72
autolites and i was told they were had a buddy do it
Old Feb 22, 2010 | 09:29 AM
Dans01Durango's Avatar
Dans01Durango
Maybe go to champions and gap them at .04 inches to diagnose the problem? HTH.
Old Feb 22, 2010 | 02:28 PM
hydrashocker
Change the spark plugs to Champion Copper Plugs gapped at .040 then go from there as Dan stated.
