Car starts but will not run
Please HELP Need My Baby Back
1999 Dodge Durango 360 V8 4x4
While driving driving the motor started to occasionally run rough. Then it started to become hard to start. this went on for about a month then it would start-up but not run. If you pressed the gas it rev's up then stalls. Replaced T.P.S. sensor, Temp sensor, Mass Air flow/temp sensor, Crank sensor, I have taken this to the shop 3 times and they tell me that there is no codes showing on the computer.
did you try cleaing the IAC motor? and check the battery, if it is more than 4 years old it has served its purpose and a low voltage from the battery (weak battery, it IS possible to pass a load test and still be bad) causes these trucks to run like crap (when mine went you couldnt keep the truck running unless you kept the jumper cables on it . . . )
