i need some advice
Old 02-26-2010, 02:08 AM
jhorn3990's Avatar
jhorn3990
jhorn3990 is offline
Default i need some advice
i recently bought a 2001 dodge durango 4x4 with the 4.7 v-8. i has 141,xxx on it and ran great the past 3xxx miles. i was driving home last night ( about 70 mph for 30 miles) and all it started missing like crazy with absolutly no warning. the check engine light popped on and i had to 2 foot it to make it home. i checked the codes and it had multi cylinder mis fire. #1, #3, and #6. i first replaced all the plugs ( the old ones have been in for a while and were burnt down to about .080. i replace with platnuim plugs and it didn`t help. so i checked the codes again and it had the same codes. i replaced all 3 coils ( oh yeah, it doesn`t have a distributor). it seemed to do a small amount better but not much at all. i still have to 2 foot it at all stop signs. i also replaced the battery cable ends to make sure it had good ground.
when i take off at stop signs it stalls for a sec or two and then takes off pretty hard ( concidering i have about half throttle) it still misses but it seems to mellow out alittle, not totally.
if anyone has any advice i would really apriciate it. you can reach me at jimmyarnold48@yahoo.com or on here, thanks
Old 02-26-2010, 07:43 AM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Dodge Forum Moderator
Repost in the first generation Durango section as this is the general forum. I would clean the throttle body and see if it clears up,
FF
Old 02-27-2010, 08:22 AM
winerocks's Avatar
winerocks
winerocks is offline
This sounds like a MAF or O2 sensor issue. At 141K, both are nearing the end of their life expectancy. Are the MAF and O2 sensors original? MAF issues typically will not generate a CEL. Start by getting a can of MAF cleaner, pull the MAF and give it a spray. If you can reach the filament with a Q-tip for a gentle rub-down it will help. This is a bandaid fix, and you should probably order a new one.
Old 03-01-2010, 02:26 PM
jhorn3990's Avatar
jhorn3990
ive replaced the plugs again, put the 3 new coils on it and replaced the intake/plentum gaskets. still runs really bad. runs really rich
Old 03-01-2010, 02:57 PM
1969CoronetR/T
vaffanculo
The guys in the first generation Durango section can help you,
FF
Old 03-01-2010, 07:39 PM
winerocks's Avatar
winerocks
Jhorn, before you spend any more money on things that won't help, look into the MAF-Mass Airflow Sensor and O2 sensors. Both play vital roles in air:fuel ratio. I would bet on the MAF in this case, it typically won't generate a CEL, but will result in random misfires and poor mileage.
Old 03-01-2010, 10:09 PM
jhorn3990's Avatar
jhorn3990
it doesn`t have a MAF-mass air flow
Old 03-02-2010, 06:45 PM
winerocks's Avatar
winerocks
So they call it a MAP (Manifold Absolute Pressure) tomato, tomato. It serves the same purpose, and causes the same problems.
Old 03-10-2010, 03:25 AM
jhorn3990's Avatar
jhorn3990
thanks for all the advice, i figured out what my problem is. on the #3 cylinder i checked compression and it had none. i pulled the valve cover off and found the exhaust rocker off and the spring compressed about 1/8tth lower than the rest. so basiclly the rocker jumped off and bent the valve.
again, thanks
Old 03-17-2010, 09:41 PM
winerocks's Avatar
winerocks
Wow, that's a little more serious than a stupid sensor! Good luck with the fix.
Quick Reply: i need some advice
