OK thought it was fixed but not
Old Mar 1, 2010 | 07:58 AM
Kevin Murphy's Avatar
Kevin Murphy
Unhappy OK thought it was fixed but not
OK thought it was fixed but not. Changed the air intake valve and it ran but now it will stall after it runs for a few minuets. It is like you turn the key off. it does not run rough at all just stops. After it stalls it is hard to start and I could here the gas pump activate twice
Old Mar 1, 2010 | 08:02 AM
Dans01Durango's Avatar
Dans01Durango
Did you goose the throttle while starting? How's your battery? Our Ds are very picky if the battery is bad.
Old Mar 1, 2010 | 08:07 AM
Kevin Murphy
it was running for 15 min then it just shut off
Old Mar 1, 2010 | 08:10 AM
Dans01Durango
Bad fuel? Have you checked the schrader valve for gas pressure? Coulld be the fuel pump going out?...
Old Mar 1, 2010 | 05:59 PM
Uller God's Avatar
Uller God
I had the same prob with the fuel pump. It would take a long crank to get it to fire, once she fired it ran fine. Finally replaced the pump, it's a PITA to replace.
Old Mar 1, 2010 | 11:51 PM
hydrashocker's Avatar
hydrashocker
I'm thinking fuel pump as well. Do a pressure test to confirm.
Old Mar 2, 2010 | 01:15 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup sounds like you got a bad fuel pump (or one thats going bad)
Old Mar 2, 2010 | 05:19 PM
Kevin Murphy
Hi guy's
Cleaned the throttle body today the D ran great drove to town (80KM) and on the way home it started to run rough and stalled. It would not restart until it cooled down. I towed it home then it ran nice again. I found today that if I started it, it would run rough so I turned it off then on again and it ran OK. Thinking that it might be the fuel pump. Will check the fuel pressure tomorrow. What should the pump pressure be. (57psi) ?
Old Mar 3, 2010 | 10:33 PM
hydrashocker
Max is 54psi (at curb idle) and anything under 50psi I would change out however people and the book have always argued this point with me I stand by my opinion.
Old Mar 4, 2010 | 09:11 AM
Kevin Murphy
Got a new pump yesterday Holly@#@##! is this thing BIG. It came in its own shipping crate! Going to put it in today. Hoping it does not take too much.
