Misfire after new Champion Copper
Old Mar 2, 2010 | 09:48 PM
SumAmerican's Avatar
SumAmerican
you will always have some build up on the plug.. even if it has been ran for just a few days.. the times when you have to be worried is if the build up is only on a few of the plugs and not all of them.. this will tell you that a certain cylinder isn't getting everything right.. spark could be too hot/cold.. too much fuel or too little.. poor atomization of the fuel.. and so on...
Old Mar 2, 2010 | 10:17 PM
bigalzoto1's Avatar
bigalzoto1
My advice is to isolate the problem to a certain cylinder. The misfire will probably be in a certain cylinder. While the engine is idleing remove one wire at a time and see if the RPM goes down. If there is a cylinder that dosent affect the engine RPM when the plug wire is removed then start there. Give the motor a compression test. If that cylinder is a lot weaker on compression than the other ones than you may have a serious problem. If that cylinder has the same compression it will not be that serious. Make sure you read the plug carefully against the other ones. Then I would swap the fuel injector with another cylinder injector and see if the motor loses RPM when plug wire is removed. If the RPM goes down than it could be a bad injector that was in that cylinder. However if it was a bad injector then the cylinder that you swapped the injector with will now have the problem and it wont change RPM when plug wire is removed. This will pinpoint the problem of a bad injecter before you go out and spend money on a new injector. However if the same cylinder dosent change RPM after swapping injectors then you know it is not a injector problem and look into ignition wiring.
Old Mar 2, 2010 | 11:05 PM
IndyDurango's Avatar
IndyDurango
Nice chart. I'm gonna steal it.
Old Mar 3, 2010 | 12:23 AM
master tech's Avatar
master tech
Site Moderator & Tech
I think everyone should, i know i will.
Old Mar 3, 2010 | 10:13 AM
gr8scott72's Avatar
gr8scott72
It's inside every Chilton repair manual. (Is it Chilton or Haynes?)
Old Mar 3, 2010 | 08:10 PM
SumAmerican
i just googled spark plug chart.. the link is posted up on another forum somewhere else.. it is a good chart tho..
Old Mar 3, 2010 | 08:22 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it is also in my online photo gallery
Old Mar 3, 2010 | 11:17 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by CudaVert
I did notice that some of the E3 plugs had some carbon buildup after running just 2 days.
There's your problem, pull those POS plugs out of that motor and replace them with Champion Coppers (Cheapo $2 plugs) and gap em .045 on the 4.7L I think).
Old Mar 3, 2010 | 11:25 PM
shrpshtr325
THE ULTI-MOD
nah its still .040 on the 4.7 hydra
Old Mar 4, 2010 | 02:38 PM
CudaVert's Avatar
CudaVert
Yea. I actually did that and am still having the same problem. Hence the thread name
I did pull it in the garage yesterday and while the engine was running, unplugged each coil one at a time. The weird thing is that I didnt notice any change in idle at all! Not for any of the cylinders
What do you guys make of that? I don't understand it...
Thanks again!
