Front end drivetrain noise
Old Mar 2, 2010 | 10:15 AM
dmeray1's Avatar
dmeray1
Default Front end drivetrain noise
I have a '03 Durango 4X4 with the 4.7l v8 and I am hearing a "sqealing" noise that seems to be coming from the right front wheel area. Also, there is a feeling of a "drag" like the 4wd did not disengage properly. Any thoughts? Bearings, brakes or hubs?
Old Mar 2, 2010 | 12:49 PM
Dans01Durango's Avatar
Dans01Durango
Could be the brake pads going on their last miles. IIRC, bad bearings will cause a grinding noise. Does the squealing noise stop when you make right turns? Or, when was the last time you saw your cat?
Old Mar 2, 2010 | 01:44 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by Dans01Durango
... when was the last time you saw your cat?
lol
but i agree, check the breaks, and the wheel bearings, if the brakes are dragging they will cause drag, and COULD cause noise
Old Mar 2, 2010 | 02:38 PM
dmeray1's Avatar
dmeray1
I need this weather to be a little nicer so I can see if one of the calipers is running hotter than another. Does anyone know how the front wheel bearings are constructed? Do I have to remove the hub or what?
Old Mar 2, 2010 | 02:44 PM
hydrashocker's Avatar
hydrashocker
LMAO!
Here kitty-kitty-kitty!........
Old Mar 2, 2010 | 03:20 PM
dmeray1's Avatar
dmeray1
BTW- Its more of a Squirrel pitch than a cat....
Old Mar 2, 2010 | 07:34 PM
shrpshtr325
THE ULTI-MOD
you will have to replace the entire hub if the bearing is bad, no other way atm
Old Mar 3, 2010 | 10:54 PM
hydrashocker
You are correct! There is no rebuilding "just the bearing" as I just finalized that right out of the book.
Here is the thread I finally found and updated: https://dodgeforum.com/forum/1st-gen...l-bearing.html
Old Mar 3, 2010 | 11:21 PM
shrpshtr325
THE ULTI-MOD
took ya long enough
