band adjustments
Old 03-20-2010, 05:23 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
Originally Posted by hydrashocker
No!
I'm saying it might not be good to install a Transgo Shift Kit on a transmission that has seen a lot of ware.
As for adjustments, YES you want to adjust a 42RE, 44RE, and 46RE transmissions when you drop the pan and replace the filter and fluid (ATF+4 ONLY).
The 45RFE (or even the 545RFE) transmissions located behind the 4.7L motor has NO band adjusters so they are only a fluid (ATF+4 ONLY) and 2 filter design.
Never flush a Chrysler transmission!
+10000000000000 on all of this,
Old 03-20-2010, 10:42 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
i dont see how a mild shift kit will hurt? it should help. like i said i am looking at the firm shift, not the snappy shift.
Old 03-20-2010, 11:52 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
The 42RE, 44RE, and 46RE transmissions are hydraulic so the only way a firm shift is going to happen is a shift kit or remove Torque Management.
Quick Reply: band adjustments
