02 durango A/C compressor, which one
Old Mar 25, 2010 | 01:02 PM
superdav's Avatar
superdav
Default 02 durango A/C compressor, which one
My compressor is knocking after running a few minutes and the temp is not very cool i've checked the idler pully and a/c clutch and both are good so i'm going to replace the compressor
i was looking at autopartswharehouse.com and they have compressors with different size ports.
which fits my 02 durango slt 4.7 with rear air?
also which compressor brands have you used? any suggestions?
Old Mar 25, 2010 | 02:15 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would check the freon level in the unit first, low freon can cause less than acceptably cold air and a number of other issues, also check for leaks in the compressor and evap lines, could even be the evap core that is leaking, i would not jump to the conclusion that the compressor is bad before going through the proper diagnosis
Old Mar 25, 2010 | 02:35 PM
superdav's Avatar
superdav
it started last summer and i checked the refridge level then and it was good, the compressor knocks like a thrown rod with a minute or 2 of running
ETA nice avatar!
Old Mar 25, 2010 | 05:26 PM
hydrashocker's Avatar
hydrashocker
Well if your sure it's bad then call the dealer and ask them what size yours is.
Old Mar 25, 2010 | 09:23 PM
superdav's Avatar
superdav
went ahead and checked the psi on the ac and its 42-44 psi and also need to figure out which O2S is bad
i got this trouble code
P0420 1/1 catalytic converter EFF
P0138 1/2 O2S shorted to voltage
anyway to test each to see which is bad? i dont have the money to take it to a dealer so i need to figure this out myself
Old Mar 25, 2010 | 11:06 PM
hydrashocker
Please start a new thread for the 02 sensor and remember to include your truck info.
Old Mar 26, 2010 | 09:06 PM
superdav's Avatar
superdav
nevermind on the sensors thats fixed but the A/C problem is still there i went to Advance auto parts, Oreilly, and Auto Zone and no one had one in stock, AZ could get one in 2 days but the guy behind the counter couldnt figure out which one went to my car even with the info on the tag on my current compressor and i couldnt get to the dealer before they closed to figure out which one fits
Old Mar 26, 2010 | 11:02 PM
hydrashocker
Just wait for the dealer tomarrow.
