Tires and rims.
Old Apr 16, 2010 | 04:37 PM
mrtoofast4u's Avatar
mrtoofast4u
Default Tires and rims.
It seems like I am the only one with 16in rims. I currently have 265/70r16 with no rubbing at all. What would be a good all terrain tire size?
Old Apr 16, 2010 | 07:48 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i got the 16" rims on mine, but i have the stock size tires (31's) if you want stock i wouldnt suggest going any bigger without at least a t/s lift
Old Apr 16, 2010 | 07:51 PM
mrtoofast4u
I want bigger.
Old Apr 16, 2010 | 08:01 PM
c00nhunterjoe's Avatar
c00nhunterjoe
a 265/75/16 is the equivalent to a 31x10.5
Old Apr 16, 2010 | 10:26 PM
Dislander's Avatar
Dislander
With the t/s lift & some trimming/relocating of the front bumper 285/75/16 will fit. the 285 is wider than the 33/1050's I ran & will need trimming that mine didn't. you will also want to relocate a connector under the splash panel drivers side front lower rear. if you have rear a/c there are some lines in the rear you may wish to protect. If you have running boards I would expect clearance issues with them as well.
I recently helped a friend of mine put these on his. after seeing my 33's he wouldn't accept less on his. the front bumper was our biggest rub point & after trimming contact is on the frame rail.
For cost & fitment I would try to source a set of 15" wheels. the cost of tire will drop a few hundred & you will have better clearance with the 1050's.
If you top off the t/s lift with a 3" body lift, body rubbing issues will go away but the frame will still be a contact point. you could fab up some turn stops to remedy that.
Old Apr 17, 2010 | 12:45 PM
Durango03's Avatar
Durango03
I have the stock 245/70/16... How do the 265's look? Have any pics?
Old Apr 17, 2010 | 01:04 PM
shrpshtr325
THE ULTI-MOD
take a look at the pics of my truck
Old Apr 21, 2010 | 02:27 PM
mrtoofast4u
What about a 34x10.50x16? The o.d. is 33.6".
http://www.offroadunlimited.com/orus...=16&width=10.5
Old Apr 21, 2010 | 03:56 PM
hydrashocker's Avatar
hydrashocker
Negatory......
