Transfer Case 4H PT, 4L PT light
Old Apr 26, 2010 | 12:56 PM
Chronic01505's Avatar
Chronic01505
Default Transfer Case 4H PT, 4L PT light
When I change into 4H PT or 4L PT the dash light showing me that it is in that gear does not show... I just replaced my transfer case because the last one I had binded uppp. When testing it out jacked up in the garage the light was engaging and just last night I tested it out. It seems to work in those gears it just doesn't show up on the dash. Curious if there is wiring problem or something.
Old Apr 26, 2010 | 11:30 PM
master tech's Avatar
master tech
Site Moderator & Tech
Was the lite working before? If it was, you could have blown a fuse or a bulb is burn out. The number 11 fuse is for the 4x4.
Old Apr 27, 2010 | 12:48 AM
hydrashocker's Avatar
hydrashocker
Could be a bulb or it is the 4X4 light switch on the T-case. I would replace the switch.
Here is some usefull info on your T-case:
Transfer Case
Axle bind causing T-case to stay engaged:
https://dodgeforum.com/forum/1st-gen-durango/75519-differences-in-4x4-pt-low-hi-awd.html
https://dodgeforum.com/forum/1st-gen...nv-242-hd.html
https://dodgeforum.com/forum/1st-gen-durango/240552-transfer-case-exploded.html
Old Apr 28, 2010 | 11:46 PM
Chronic01505
Ok well I was sitting parked in the parking lot and decided to test it out again an the light did come on this time. Although it was dim and flickering a little bit. Not sure bad connection or what?
Old Apr 29, 2010 | 04:32 PM
hydrashocker
It's a bad range switch on the T-case.
Which T-case do you have?
Old Apr 29, 2010 | 10:11 PM
Chronic01505
231d hd...
Old May 1, 2010 | 05:41 PM
hydrashocker
It's located just above where the selector shaft goes into the NV231 Transfer Case.
