Replacing liftgate..HELP
I have decided to replace the liftgate because of the rust. I found a good one in the same color at the wreckers. Is it a straight forward process? Does the wiring harness to the door just unplug at the top? Will the latch work properly? There is no key with the new / used replacement door. Anything else I need to be aware of ? I've looked for threads about the replacement but have found nothing...which is surprising ( or re-assuring) 'cause I'm sure many doors have been replace due to rust....at least in the north. HELP please,any links to DIY on this subject or just general resources or source for manual info. . etc.. thnax
Wiring did change in some of the years so you need to check the harness and ensure it's the same as yours. Where it is I don't know. Make sure you get everything just in case you have to gut yours and replace the wiper motor. Everything else is the same if i remember right. Look into your door first before you mess up the stuff you might need on the junker.
Lewiston NY.....thanks for the offer...but I don't EXPECT and problems I can't deal with. It's the SURPRISES I don't like........like different wiper motors or lock assembly. And how hard is it to get the inside trim cover off without destroying the connectors ? Should I buy somw new ones? It's almost impssible to find one without rust...esp. up here....and in the right color...so I had to get it !
I just replaced the tailgate on my 98 Durango with one that was from a later year - exact year unknown - and can verify the wiring is different. Although all the connectors on the new gate were the same the rear wiper blows a fuse when turned on (intermittent wipe) but works if I press the button for continuous wipe & wash. However when I release the button the wiper stops where is without resetting to the rest postion. I did save the old harness /wiper motor but will first see if I can find wiring diagrams for the original and replacement gate to see if I can make a simple wiring change vs swapping the harness and/or motor.
Yes, the insides changed completely in 2000 relating to the wiper/pump. 98/99 match and 2000-03 match close enough internally to be fairly interchangable. IIRC, there were small vendor changes from 2000-03 on pump and motor so they may be tiny differences, but again, generally the same. That can not be said for the 98/99s.
IndyDurango
IndyDurango
Trending Topics
IndyDurango
IndyDurango
- Remove the tailgate panels and note the connector going to the tailgate wiper motor has three wires - black, brown/pink, brown/light green.
- At 3" above the connector cut the brown/pink and brown light green wires
- Connect the harness end of the brown/light green wire to the wiper motor connector brown/pink wire.
The rear wiper/washer switch will faction as follows:
1. Pressing the switch will activate the washer but will not activate the wipers.
2. Turning the switch to the on position will activate the rear wiper continuously.
3. If you press the switch while in the on position the washer will activate
4. When you turn the wiper off do so when in the park position as there is no functonal park sensor.
You lose the intermittent wipe feature, wiper park when turning off and wiper activation when pressing the switch in the wiper off position but much easier then replacing the 2002 motor and harness with ones from a 1998
As I have the tailgate harness, wiper motor assembly and lock actuator from my 98, it is available to anyone who wants it for the cost of shipping.
The following users liked this post:
Nate Reilly (05-16-2021)
