Thread size?
Thread size?
Can any one tell me what the thread size is for the 2 Bolts that hold the front calipers on. I have a 2000 Durango SLT with the 5.9L engine. I ordered the bolts from the dealer but the threads need to be re-tapped so nobody seems to know what size tap we will need. If any of you Gurus know the correct tap to use I would appreciate you dropping that knowledge on me so I can finish this brake job. The bolts arrive at the dealership tomorrow.
Thx - John aka CyrusBlack
Use the oversized bolts from NAPA for this exact problem... folks stripping out the original caliper bolts via Part # BK6751539
https://www.napaonline.com/
HTH,
IndyDurango
HTH,
IndyDurango
on
NO: 05-03-99
SUBJECT: Front Brake Caliper Mounting To Steering Knuckle Thread Repair
DATE: Apr. 23, 1999
OVERVIEW:
This bulletin involves repair of the threads on the steering knuckle or brake caliper mounting adapter that are used to install and retain the front brake caliper housing in its correct operating location.
DISCUSSION:
A Brake Knuckle Thread Repair Kit has been developed to repair stripped threads on the front brake caliper mounting attachment making it no longer necessary to replace the front steering knuckle/brake caliper mounting adapter when encountering stripped threads. The following information provides the repair procedure for using the Brake Knuckle Thread Repair Kit.
DIAGNOSIS:
Place the vehicle on an appropriate hoist.
Remove the front tire/wheel assembly.
Remove the brake caliper housing assembly by loosening the mounting bolts.
NOTE: IF HIGH TORQUE IS ENCOUNTERED DURING THE MOUNTING BOLT REMOVAL, IT IS LIKELY THAT THREAD DAMAGE WILL OCCUR OR HAS OCCURRED.
Remove the caliper housing assembly and hang the housing on the frame of the vehicle using an appropriate wire hanger.
NOTE: DO NOT ALLOW THE CALIPER HOUSING TO HANG BY ITSELF FROM THE BRAKE HOSE AS DAMAGE TO THE HOSE MAY RESULT.
If the vehicle has a bolt-on brake caliper mounting adapter, remove the adapter. If the brake caliper mounts directly to the steering knuckle, remove retainers on the wheel studs and remove the rotor.
Inspect the mounting bolts and knuckle threads for damage. If either is damaged, it is likely that damage to the other has occurred as well. If damage has occurred to the threads in the form of knicks, thread pulling, or cross-threading, perform the Repair Procedure.
PARTS REQUIRED:
Qty Part No. Description
AR (1) 05016155AA Kit, Brake Knuckle Thread Repair Includes:
23/64 Drill Bit
M9 X 1.25 Tap
Heli-Coil Installation Tool
Heli-Coil Tang Break-Off Rod
(25) M9 X 1.25 Stainless Steel Heli-Coils
REPAIR PROCEDURE:
Using the 23/64 in. drill, drill through the brake caliper mounting attachment hole keeping the drillperpendicular to the knuckle.
Using the M9 X 1.25 tap, tap the drilled hole ensuring to tap the hole entirely through.
Install a Heli-Coil insert onto the installation tool (tool number 3747-9). Be sure the tang is properly engaged into the driving contour of the tool.
Install the Heli-Coil into the drilled/tapped hole by rotating the tool and exerting slight pressure onto the tool/Heli-Coil and into the drilled/tapped hole. Continue to rotate the tool until the insert is located 1/4 to 1/2 turn below the steering knuckle surface.
Back the Heli-Coil installation tool out of the installed Heli-Coil. Then, remove the tang from the Heli-Coil by breaking the tang off using the tang break-off tool. Place the break-off tool into the assembled insert until it rests on the Heli-Coil tang. Holding the tool squarely, strike the tool sharply with a hammer.
If the vehicle has a bolt-on brake caliper mounting adapter, install the adapter. Refer to the appropriate Service Manual for information regarding proper brake caliper adapter mounting information. If the brake caliper mounts directly to the steering knuckle, install the rotor.
Install the caliper using new mounting bolts p/n 04886075AA in any location that had a Heli-Coil installed. Tighten the bolts to 30 - 35 N• m (22-26 ft. lbs.).
Install the tire/wheel assembly.
Lower the vehicle.
DATE: Apr. 23, 1999
OVERVIEW:
DISCUSSION:
DIAGNOSIS:
PARTS REQUIRED:
23/64 Drill Bit
M9 X 1.25 Tap
REPAIR PROCEDURE:
Lower the vehicle.
