A/C Problem
Old Jun 1, 2010 | 06:05 PM
zachalex111's Avatar
zachalex111
Well thanks everyone, I'll check into the drier and the 134
Old Jun 2, 2010 | 12:31 AM
skipatrol80's Avatar
skipatrol80
i have the similar issue with my 03, i fixed the blend door, and got it to cool at low ac blowing speeds, but when the ambient temp gets high, it just cant cool...it makes me sick cuz you cant really fix a poor design w/o a complete overhaul...their are ways to help things, i turn my durango on and let it run and keep the ac on low for a little bit before i get in it to go, otherwise its a heat trap...but i cant run both the front and rear at the same time, i can run one or the other to get some cool air. it clearly blows cold, just cant crank it up...then it blows hot
Old Jun 2, 2010 | 03:34 PM
hydrashocker's Avatar
hydrashocker
Sounds low on freon?
Old Oct 2, 2010 | 06:32 AM
njemt24's Avatar
njemt24
Default 2003 A/C Prob
How hard is it to fix the blender door? I have the same problem and the shop told me thats what the problem was and it be $1000 to fix. Also where would I look to get info on how to fix it?
Old Oct 2, 2010 | 09:29 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
http://www.mediafire.com/?2cg2hgim2zz
2002 shop manual, should have everything you need,
i believe you have to pull the dashboard out in order to get to the part
Old Oct 2, 2010 | 01:49 PM
hydrashocker
I think the 2001-2003 you can get to the blend door actuator without removing the dash.
