whurring noise from back
Old Jun 3, 2010 | 02:21 PM
sablepilot's Avatar
sablepilot
Default whurring noise from back
Its the best I can explain it. I hear a whurring noise that I first thought was the tires...but its not. The whurring noise increases with speed and decreases as I slow down. Any ideas what this could be?
thx in advance...tim
Old Jun 3, 2010 | 07:28 PM
45AutoPete's Avatar
45AutoPete
When was the last time you did a rear diff. oil change? How many miles on the vehicle? What kind of vehicle? Size of engine? We need further info on the above and also what size rear end you have along with gearing.
Old Jun 4, 2010 | 03:51 PM
hydrashocker's Avatar
hydrashocker
+1 Pete!
Old Jun 6, 2010 | 06:49 AM
sablepilot's Avatar
sablepilot
I thought it might be the Diff so I had it changed 100 miles ago...No change in the noise. Its a 1999 Dodge Durango 4x4 with a 5.2 liter V8. It has 134,000 miles on it.
Old Jun 6, 2010 | 09:33 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
do you have a limited slip rear diff? if yes, did you remember to put the friction modifier into it? if not, do it NOW do not pass go, do not collect $200 go straight to the store for friction modifier
Old Jun 6, 2010 | 03:50 PM
hydrashocker
Could also be a wheel bearing.
You can always take it in for a second opinion?
Old Jun 6, 2010 | 10:57 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does the sound coming from the rear,or the center of the truck? Because there is a bearing inside the overdrive unit that goes bad. Most people think its the rear diff or transfer case.
