Trurn signals wont work
Old Jun 5, 2010 | 10:37 AM
Jordan91ulbrich's Avatar
Jordan91ulbrich
Default Trurn signals wont work
My turn signals on my durango will not work. i changes the relay and nothing. they have ben fixed before by a shop and i dont wanna take it back. any idea what is wrong.
Thanks Jordan
Old Jun 5, 2010 | 04:06 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check the combination flasher, it controls the flashers and when it goes it could cause this, and i believe the part costs $15 so its not an expensive thing to try
Old Jun 6, 2010 | 12:39 AM
hydrashocker's Avatar
hydrashocker
It is located in the dash fuse panel very bottom and is square (at least for the 1998-1999).
Old Jun 6, 2010 | 06:20 PM
Jordan91ulbrich
ya tried that done work
Old Jun 6, 2010 | 06:30 PM
shrpshtr325
THE ULTI-MOD
check the wiring, look for broken insulation, frayed wire, loose/broken connection, bad ground, dirty ground, and then check to make sure all the bulbs are making contact, also make sure that the blinker filament in each bulb is still good, i would be surprised if they were all bad, but anything is possible.
the other thing to check is the multi-function stick which controls directionals, wipers, washer and high beams it could be bad and not sending the right signal out the wires
Old Jun 6, 2010 | 10:21 PM
master tech's Avatar
master tech
Site Moderator & Tech
When did the turn signal stop working and does the 4 way work?
Old Jun 6, 2010 | 11:43 PM
Jordan91ulbrich
no flashers dont work either
Old Jun 7, 2010 | 12:16 PM
hydrashocker
So you replaced the Multi-Flasher and it still doesn't work?
Next check and relays and fuses or it could be a brake light swtch. Lastly if everything checks out and power is going into the CTM and not coming out then it is the CTM but a test of voltage should be completed.
Also check your trailer plug.
