lost my headlights, domelights, power locks and more.
Old Jun 8, 2010 | 08:15 PM
BigDog95670's Avatar
BigDog95670
Default lost my headlights, domelights, power locks and more.
ok i'm so lost. i lost my headlights my domelights my powerlocks my 4wheel drive indacator lights my parking brake light and the pannel lights that light up do you can see how fast your going at night. i check all fuses and all relays and they all seem to be ok. i check for power to the fuses and relays as well and i got that to. i have not gone 4wheelin or any off road in over a moth. and what little i did i didnt have any water or puddles that i went throught. i have heard of some thing called a CTM but not sure if thats got any thing to do with it. please guys i really need your help with this on. truck specs 2001 durango 4.7 slt magnum. any thing might help. thanks agian.
Old Jun 8, 2010 | 10:31 PM
hydrashocker's Avatar
hydrashocker
Sounds like a CTM to me.
Old Jun 8, 2010 | 10:35 PM
BigDog95670
any clue where shes located and if i can reset it or do i need a new one. i have head the ctm can be reset by undoing the bat and unplugging the ctm the hooking it all back up again. is this right and again where is the ctm on the 01D? thanks
Old Jun 8, 2010 | 10:36 PM
master tech's Avatar
master tech
Site Moderator & Tech
I had this same problem on a 2002 durango. It was the central timing module (CTM) just like hydrashocker had said.Replace the CTM and program the remotes and all lights and door locks came back to life. So thats a plus 2 on the CTM.
Old Jun 8, 2010 | 11:02 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
its the CTM, in the driverside kick panel
follow this
http://www.mediafire.com/?kwmwzuvymmf
Old Jun 11, 2010 | 12:10 AM
BigDog95670
does it need to be reprogramed by the dealer? will any used one (if working ) from a picknpull work.? thanks for all the help guys.
Old Jun 11, 2010 | 07:34 AM
shrpshtr325
THE ULTI-MOD
yes it needs to be programmed by the dealer, but you can buy and install it yourself in the parking lot if you want to save their installation costs
Old Jun 11, 2010 | 06:07 PM
IndyDurango's Avatar
IndyDurango
TIP: Take BOTH key fobs with you when you go in for reprogramming.
IndyD
Old Jun 11, 2010 | 11:16 PM
BigDog95670
IndyD
i have a after market Viper alarm... so will i need those reprogramed? or are you talking about the stock key fobs. and why does it need to be reprogramed. why window and locks and lights are the same from durango to durango if its the same year. or am i missing something.??
Old Jun 11, 2010 | 11:21 PM
shrpshtr325
THE ULTI-MOD
he means the factory key fobs, and they need to be programmed to your specific set of features, chrysler used one unit for all the trucks, so the features that you have need to be turned on, and the ones you dont off
the ctm is also the reciever unit for the factory key fobs so take them with you
