Steering wheel controls stopped working!
Old Jun 20, 2010 | 12:57 PM
Dreddlox's Avatar
Dreddlox
Unhappy Steering wheel controls stopped working!
Hi Folks! I'm hoping I'm not the first with this problem and that someone will lead me in the right direction! I have no power for any of the controls on my steering wheel. Horn, volume, cruise and I'm assuming the air bag may be in that equation. I checked the fuses and they are in order. Is this a problem that has been encounted before and is it an easy fix, or am I stuck in the hands of a Dodge dealership?
Any info would be appreciated.
Thanks!
Old Jun 20, 2010 | 02:41 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you need to replace the clock spring, not something i would attempt myself as you have to remove the airbag to get at it. IMO take it to a dealer or a shop to get it replaced, this way if they f- something up, they are on the hook to fix it.
(btw the clock spring is the device that runs all the wiring into the steering wheel)
Old Jun 20, 2010 | 05:39 PM
hydrashocker's Avatar
hydrashocker
+1 Sharps!
Old Jun 20, 2010 | 06:15 PM
master tech's Avatar
master tech
Site Moderator & Tech
Dreddlox
What year is your durango, and is the air bag lite on? I ran across this same problem about 5 years ago. There was a large connector under the dash and the pins in the connector were turnning green and causing a bad connection,to the radio volume,speed control and horn.But i would not rule out the clocksping.
Old Jun 21, 2010 | 02:34 PM
Dreddlox's Avatar
Dreddlox
Thanks for the quik replies! My Durango is a 2001! I'll check the harness under the dash just to rule that out before taking the plunge! The airbag light has not come on!
