Please help 1999 dodge durango auto
Old Jun 23, 2010 | 09:28 PM
ykkrs's Avatar
ykkrs
Default Please help 1999 dodge durango auto
this durango is showing codes Po733- gear 3 ratio incorrect and po734-gear 4 ratio incorrect. how can a person correct these?
Old Jun 23, 2010 | 09:58 PM
03SxtD's Avatar
03SxtD
if you have a superchips tuner you can reset the codes... or you can try resetting the pcm.
Basically remove the negative side to the battery and then reconnect, see if you get the codes again
Old Jun 23, 2010 | 10:25 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
to reset the pcm you disconnect the negative battery terminal, and either leave it off overnight, or turn the ignition key to start for 30 seconds to drain any residual current from the capacitors in the system, if you do not do one of these you WILL NOT reset the PCM
and those sound to me like transmission codes, i would get in touch with master_tech, he is the local trans expert
Old Jun 24, 2010 | 01:10 AM
hydrashocker's Avatar
hydrashocker
Sounds like a 1st/2nd shift solenoid or Governor to me.
Old Jun 24, 2010 | 01:26 AM
ykkrs's Avatar
ykkrs
So Hydrashocker, where could these be located?
Old Jun 24, 2010 | 12:03 PM
hydrashocker
Here: https://dodgeforum.com/forum/1st-gen...-question.html
Old Jun 24, 2010 | 12:55 PM
ykkrs's Avatar
ykkrs
I left out something, in drive it won't go over 25 mph, but in 1st and 2nd it works fine.
Old Jun 24, 2010 | 01:06 PM
Dans01Durango's Avatar
Dans01Durango
Yep, tranny issue. Calling master tech!
Old Jun 25, 2010 | 02:02 AM
ykkrs's Avatar
ykkrs
Anyone wanna add to this thread?
Old Jun 25, 2010 | 01:31 PM
hydrashocker
Talk to master tech about this.
