BCM or CTM for '99 Durango wanted
I am looking for the Body Control Module (or Central Timing Module it's also called) for a '99 Durango. Preferably one out of a truck with the overhead console, if there's a difference.
Also, can anyone tell me where to find the CTM itself in a '99 DUrango? I searched on here, and other than some "maybe it might be" posts, I didn't find anything that definitely stated the location. If I could find it, I could get the exact part number off it.
The parts numbers I found are: R6040106-AH or R6040147-AG.
My truck originally had the 5.2, but we did the 5.9 swap a few years ago, and bought a Mopar Performance PCM for the 5.9 from a seller here. It still has the original CTM that came with it, and until recently it worked fine.
The dash lights and running lights quit working, and nothing will dim. Replaced the headlight/dimmer switch, but that didn't help. Fuses were ok, but wasn't getting power to the 5 amp fuse. The idiot lights work in the dash, though, but not the gauge lights and so on. According to what I've read in this forum, it sounds like the BCM/CTM.
So, that's what we'll try next.
Anyone have a working BCM/CTM that will fit a '99 Durango? Please PM me or post here, thanks!
CTM faulty
Hello dodge owners.
My Dodge Durango SLTplus is showing "Check 4WD" and has been for some time. The switch for the 4wd was operating normally and shifting into all drives, but just a few days ago, it would not do anything. First I tought it might be the CTTM but I removed the CTM (control time module) and examined the module. Did not see any corrotion or any water damage, so replaced the module and removed the fault light by disconnecting the battery cable. Everything is working again, i.e. gear shifter into all drives, but the "check 4WD" light came back on after two engine starts.
This confirms to me that the module I need to replace is the CTM and not the CTTM. Can anyone re-confirm that this is the correct assumption?
Thank you,
Icedodge
Thank you,
Icedodge
I really need to be sure, because the cost of shipping and import taxex to Iceland is very high. Everything is doubled.
Thanks again.
if thats the case then you need to get underneath and start testing power signals with a volt meter,
also there is no standard mode of failure for the CTM, electronics just stop working, or seem to gain a mind of their own, dome lights acting up could be a sign of a bad CTM, or a sign of wiring problems to the lights or switches.
and quite honestly all of the electronic modules reset when you disconnect the battery (something you should have done if you pulled the CTM), so either one of them is bad would have reset and potentially 'fixed' the problem.
also i just spent some time reading about the CTM and the TCCM in the 2002 service manual(these parts are the same between these two years as are many others) and there is not reference to them talking to each other in the manual.
have a read through section 8e in this PDF http://www.mediafire.com/?2cg2hgim2zz
TCCM problem
I really appreciate your help on this problem. I removed all the plugs from the TCCM and found no signs of corrosion or a bad connection. Reconnected the battery and the "Service 4WD" light came back on after two starts. The switch is working and it will engage into the 4WD. I did read the PDF your attached with your reply and you are absolutely correct when you say that there is no reference to the CTM and TCCM talking to each other. I will change out the TCCM, when I can find one. I will keep you posted on the change.
Thanks again.
Icedodge
