front end noise
Old Aug 12, 2010 | 06:53 PM
cookcp's Avatar
cookcp
Default front end noise
I have a 2002 slt 4x4 95000k, I have a intermitant grinding noise coming from the pass front. (it started 4 hours ago after a panic call from my wife) I took it out for a drive and I heard the noise a couple of times mainly after I turned and started to give it gas.
I pulled the wheel and brakes off to check it out and I think my wheel bearing is ok.
I think the noise is coming from the bearing where the front drive shaft goes into the transfer case. The seal looked a little wet and when I rotate the hub there is a definite noise.
Is this something a weekend mechcanic can fix??
Any help from the experts is much appreciated.
Old Aug 12, 2010 | 11:39 PM
IndyDurango's Avatar
IndyDurango
It is a 30 minute fix. Replace the entire hub and you get the bearing for free (the only way it comes actually. )
It comes off as exactly as it looks like it would. Nothing special.
Easy. Done.
IndyDurango
Old Aug 12, 2010 | 11:43 PM
duramgo03's Avatar
duramgo03
Does the sound go up and down with the speed your are traveling at? i.e. higher speed faster sound, lower speed slower sound. If the sound is changing pitches it's most likely your bearing. I had 92,000 miles on my D when I had to change my RF hub assy. I think the LF, on my D, is starting to make noise now.
Old Aug 14, 2010 | 12:26 AM
master tech's Avatar
master tech
Site Moderator & Tech
SUSPENSION AND STEERING SYSTEM DIAGNOSIS
CONDITION POSSIBLE CAUSES CORRECTION
FRONT END NOISE 1. Loose or worn wheel bearing. 1. Replace wheel bearing.
2. Loose or worn steering or suspension components. 2. Tighten or replace components as necessary.
3. Lower ball joint (4x4) 3. Gease joint and perform diagnosis and testing.
EXCESSIVE PLAY IN STEERING 1. Loose or worn wheel bearing. 1. Replace wheel bearing.
3. Loose or worn steering gear. 3. Adjust or replace steering gear.
FRONT WHEELS SHIMMY 1. Loose or worn wheel bearing. 1. Replace wheel bearing.
3. Tires worn or out of balance. 3. Replace or balance tires.
4. Alignment. 4. Align vehicle to specifications.
VEHICLE INSTABILITY 1. Loose or worn wheel bearing. 1. Replace wheel bearing.
3. Tire pressure. 3. Adjust tire pressure.
EXCESSIVE STEERING EFFORT 1. Loose or worn steering gear. 1. Adjust or replace steering gear.
2. Column coupler binding. 2. Replace coupler.
VEHICLE PULLS TO ONE SIDE 1. Tire pressure. 1. Adjust tire pressure.
2. Alignment. 2. Align vehicle to specifications.
3. Loose or worn steering or suspension components. 3. Tighten or replace components as necessary.
4. Radial tire lead. 4. Rotate or replace tire as necessary.
5. Brake pull. 5. Repair brake as necessary.
6. Weak or broken spring. 6. Replace spring.
7. Ride height 4WD only. 7. Measure and adjust ride height.
Old Aug 14, 2010 | 06:40 AM
cookcp's Avatar
cookcp
Thanks guy's...new hub and it took me an hour to replace.
Love this site!!
