Help
Hi Guys
Im Back. the dodge still stalls when warms up. I have changed the TPS, Crank sensor, Mass airflow sensor, Temp sensor, Ignition Coil, Fuel Pump, Had the ECM checked and updated, Choke assembly, Tune up, and it has no codes showing. Need help guys, wife is going to cut my boys off if I don't get this running this week.
I have a 5.9 L Magnum engine. the car is a 1999 Dodge Durango.
![Icon Confused](https://dodgeforum.com/forum/images/smilies/icon_confused.gif)
The engine runs nice until it gets hot then it is like someone has turned off a switch. I installed a new fuel pump and had the same problem. I have never head of a 02 sensor doing this. I could see if the engine was running poor but it runs good. I am thinking mayb the pickup coil in the distributer may be overheating and braking down. I have put so much money into this car I am starting to think I am flogging a dead horse
My wife really needs this truck, but I don't know.
When this first started it would only happen once and a while but now if you leave it running for over 15 minuets it will turn off. changed almost everything and wondering if it could be wiring?
Really need help on this one guys.
![Icon Deadhorse](https://dodgeforum.com/forum/images/smilies/icon_deadhorse.gif)
Trending Topics
just bc you havent seen it doesnt mean its not possible, and since the o2 sensor controls the a/f mixture, if its not getting a reading the computer will not know what to do once the engine is warm, you could start checking the wires for the pre cat o2 sensor going back to the pcm, with all the parts that you have thrown at the problem i would have thought you already checked EVERY SINGLE electrical connection, but if not i would do that too.
