How many miles on your truck?
Old 12-07-2010, 09:09 AM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
Originally Posted by Turbozcs2003
So what is the secret to make the 46RE live, besides fluid and filter changes??
Everyone with the higher miles, are you on orignal transmission?
Just don't beat the hell out of it and do the proper maintenance on it and fluid/filter changes according the schedule. I've had my baby for going on 11 years now with the original tranny (2000 bought it off the showroom floor) and its got a little over 122,000 miles and still drives like brand new.
OH, and I've had it pulling a trailer 30% of its life.
  #22
Old 12-07-2010, 11:27 AM
1999_Durango_SLT's Avatar
1999_Durango_SLT
1999_Durango_SLT is offline
121,xxx on my 99 D all still original. The only issue I have had that was major was a few lifters going bad. I think it is my fault on that for running the Bosch Plat plugs in it. But my Gass Mileage sucks get about 8-9 in town and maybe 12 on the highway.
  #23
Old 12-07-2010, 02:02 PM
02 Durango_R/T's Avatar
02 Durango_R/T
02 Durango_R/T is offline
Just turned 62k
  #24
Old 12-07-2010, 05:06 PM
Pwall's Avatar
Pwall
Pwall is offline
108,xxx
  #25
Old 01-26-2011, 06:54 AM
nealeyandjon's Avatar
nealeyandjon
nealeyandjon is offline
Second confirmed owner of a 99 slt w/5.2 4x4 biught from an auction for 1200.00. With 147,000 miles on the ticker. I invested 4000.00, to rebuild front suspension brakes tune up battery tire. I replaced all the bushings front and rear new hub assemblies to include ball joints uppers and lowers (both were original from the factory) tie rods inners outers. All of the brake lines to include hoses master cylinder power brake booster front callipers and pads rear wheel cylinders and shoes had the drums turned new alt water pump power steering pump complete tune up plugs wire cap rotor. New sensors on throttle body cleaned thottle body 5 new tires and a 4wheel life time alignment flushed engine oil twice then trans twice flushed cooling system till there wasn't any more rushtcoming out about five times after all that i've put 10,000 more miles on it i get 15 miles per gallon in the city and 22 on the highway but i give it new plugs and basic tune up stuff every 3,000 miles(bought the lifetime warranty wires cap rotor parts so the only thing i really pay for is the new plugs) oh yeah i use mid grade fuel and high mileage synthetic valvoline oil 10w30 lucas fuel additive AND PS I DRIVE THIS D VERY HARD s
  #26
Old 01-26-2011, 08:51 AM
MAGIC84's Avatar
MAGIC84
MAGIC84 is offline
134K.......Transmission fail at 76K.....Rear pinion seal about 100K water pump at 101K....Hub bearing 108K......... Radiator at 116K new upper Ball Joints at 133K . Those are probably the major failures. The usual maintenance items like bulbs, tires, oil changes etc..... but so far so good. I flushed and changed the differentials and transfer case fluid about 127K.
FYI I got over 70K out of what were supposed to be 50K tires and still had about 3/32 tread on them when I replaced with ANOTHER set of Michelin X Radials. A lot to be said for proper scheduled maintenance including tire pressure checks and rotations.
A lot to be said for proper scheduled maintenance and rotation.
  #27
Old 01-26-2011, 09:42 AM
bowhuntmaine's Avatar
bowhuntmaine
bowhuntmaine is offline
Just turned 150,000 miles. I'm waiting for the engine to wear out so i can go to a stroker, but the engine has lost nothing. I think i have a long wait.
  #28
Old 01-26-2011, 09:45 AM
Dans01Durango's Avatar
Dans01Durango
Dans01Durango is offline
That's a good thing, right?
  #29
Old 01-26-2011, 09:54 AM
bowhuntmaine
It's a good thing, but i want my stroker. Can't justify tearing a good engine down (well i can, but my better half will frown on it).
  #30
Old 01-26-2011, 12:01 PM
coreybv's Avatar
coreybv
coreybv is offline
The truck as a whole is starting to have some of the small, annoying issues that vehicles tend to get when they get some age on them, but the motor still runs like new. Just recently replaced the water pump, timing chain and timing gear, and serpentine belt and tensioner (All taken care of in one trip to the shop for just under $500). That's the only attention it has required other than oil changes and tune ups.
Quick Reply: How many miles on your truck?
