Burning oil !!! 2001 5.9L RT
Old 11-29-2010, 06:53 PM
CJYJ's Avatar
CJYJ
CJYJ is offline
Question Burning oil !!! 2001 5.9L RT
I have noticed the last couple of oil changes that I am low on oil about a quart. A couple of weeks ago I took a trip and put about 1,300 miles on the truck and noticed when I got back I was low 1.5 quarts. My truck has 160,000 miles. I have no oil leaks from looking around the engine. So I take it she is getting tired and getting some blow by. Any ideas if certain oils will minimize this? Thanks
Old 11-29-2010, 10:09 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
plenum.
look straight down the TB. If it isn't rusty and dry, and instead is moist or oily, there's the issue.
IndyD
Old 11-30-2010, 07:56 PM
CJYJ's Avatar
CJYJ
CJYJ is offline
Whats TB ?
Old 11-30-2010, 09:32 PM
mrwilliwizard's Avatar
mrwilliwizard
mrwilliwizard is offline
tb = throttle body
Old 12-01-2010, 08:41 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Sounds like a blown plenum as Indy states. It might have a lot of oil puddled down in the bottom of the intake manifold. Look down the Throttle Body with a flash light to confirm.
Old 12-07-2010, 02:16 PM
02 Durango_R/T's Avatar
02 Durango_R/T
02 Durango_R/T is offline
This will affect mileage too, right? I have the same issue, adding anywhere from 1 to 2 quarts every few weeks. I get 10 mpg all day long (but I also make frequent short trips). I've looked down the TB in the past, but the butterfly design makes that a little tricky to see right, & I saw no issues.
Old 12-07-2010, 03:20 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
yes a bad plenum will most likely hurt your gas mileage
Old 12-18-2010, 11:07 AM
ModT's Avatar
ModT
ModT is offline
Hey My trucks the same way. its got 140,000km, and i did the intake and the plenum, and i dont think its burning oil, there is no smoke at all, minimal, Im thinking its an actually motor problem, my valve seals or piston rings maybe, In one week, probably 500-1000km, I had noooo oil. It was right down to the bottom of the dipstick, I didnt think that it would burn that quickly so I never checked it for 4 days, and I was down 4L. Thats almost a whole oil change. If any one knows anything about why, any other reasons other than intake and plenum I would love to know. Thanks Hope you solved your problem CJYJ!!
Old 12-19-2010, 12:32 AM
hydrashocker
WOW!
Only 4 days to almost empty the motor! That right there is a lot of freakin oil!
Your issue could be a bad valve guide, however if this was the issue you would have a puff of oil (blue smoke) on cold start up. If this isn't your issue then lets move on.
Pull your spark plugs and look at them for any oil fouling. Then do a compression test. If everything looks good, and you still can't figure it out I would do a Fully Synthetic Oil change. See if it eats oil the same way, if anything the extra added detergents will help you figure out what the issue is.
Replace the PCV valve.
It could be a ring issue, but I would think you would be burning oil (blue smoke) during driving.
Old 12-19-2010, 09:45 AM
CJYJ's Avatar
CJYJ
CJYJ is offline
Confirmed guys it is the plenum. I finnally looked down the intake and it is moist and oily. OK now what is involved to fix this? What do I need to order to fix it? Or what is the estimate in hrs to pay to get it done? Thanks guys always leading me in the correct direction here!!!!
Quick Reply: Burning oil !!! 2001 5.9L RT
