Remote start
Old Dec 14, 2010 | 11:32 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by shrpshtr325
i remember that thread, but i dont remember getting pictures, and btw hydra i dont have an alarm in my truck so there :P
Ya right,
It was standard equipment. If you have a key FOB then you have a security system. If you don't have a key FOB then you need to get one. If you do have a key FOB then I want to see it cause I smell some BS around the corner.....LOL.....
Old Dec 14, 2010 | 11:54 PM
WhiteWidow00's Avatar
WhiteWidow00
Yeah I have a key fob and when I hit locks all it does is honk the horn. I just tested it for everything I could imagine an alarm would deter and nothing. I was inside the truck and locked and opened the door, nothing. I locked again then tried to start the vehicle, started up no problem and no alarm or anything. Also, when I lock the doors there is no security light or anything telling me there's a stock security system.
Old Dec 15, 2010 | 12:18 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup sounds about right, there is no security system in my truck, nothing stops it from being started, nothing goes off if you hit the truck while its parked and locked the only thing the remote does is to lock and unlock the doors and activate the panic button, that IT absolutely NOTHING ELSE, no alarm or remote start or anything
Old Dec 15, 2010 | 12:44 AM
hydrashocker
Open a door without using the key or without using the key FOB after the you press lock with the key FOB! Basically, unroll the window and hit the lock on the FOB. Then walk over to the passenger side door or drivers door and unlock it and open the door. Bet it goes off.
I don't know about a starter disconnect, reminds me of past threads, but I don't fully remember if it shuts it down or not.
Old Dec 15, 2010 | 12:53 AM
shrpshtr325
THE ULTI-MOD
nope, doesnt set it off i have opened it through the open window in the summer many times with both inside and outside door handle. i also have the factory window sticker around somewhere, ill double check tomorrow but i do not recall seeing anything about an alarm system on there, i think you are wrong.
Old Dec 15, 2010 | 02:40 AM
TODSHO's Avatar
TODSHO
My wife has a 01 Durango and I baught her a Compu Star last year...works real well and you can still use the factory remotes to lock and unlock the vehicle as well as the starter remote. you can also set the run time to 15,20 or 30 minutes and it will automaticly shut off. You can also set it to automatically start every 30 min or every so many hours to keep the vehicle warm or cool for that matter...very happy with it. and it works with the factory alarm...
Old Dec 15, 2010 | 04:31 AM
oklahomafbody's Avatar
oklahomafbody
I put an Autopage remotestart/ alarm with paging remote in our 98. Love it. Everything works as it should.
Old Dec 15, 2010 | 12:22 PM
shrpshtr325
THE ULTI-MOD
hydra, my build sheet here ya go
and if you want a video of my truck NOT having an alarm i can make one for you
Old Dec 15, 2010 | 01:44 PM
hydrashocker
WOW!
I stand corrected "again"......LOL
I saw something else on your build sheet as well, the tow group has a 160 Amp Alternator. I wonder if they were installed in the 2000+ versions only? Also never seen them in the stores so I went and looked, SOB your right! I wonder if they can be installed in the 1998-1999's?????
My build Sheet from the dealer:
Dear Rustin:
Thank you for your email to DaimlerChrysler Motors Corporation
regarding
your 1998 Dodge Durango.
According to our records, your vehicle was equipped from the factory
with the following:
*LJ - Leather Trimmed Bucket Seats
-K9 - Camel/Tan
ADAP - Light Group
ADHP - Heavy Duty Electrical Group
ADJ - Heavy Duty Service Group
AFHP - Interior Convenience Group
AHC - Trailer Tow Group
AJBP - Security Group
AJKP - Convenience Group
AJPP - Power Convenience Group
APAS - Monotone Paint
ASPP - SLT Decor Group
A07P - 5.9L Engine(EML)/4Sp Auto Trans(DGT)
BAZP - 136 Amp Alternator
BCQP - 750 Amp Maintenance Free Battery
BGJS - Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS - 11x2 Rear Drum Brakes
CADP - High Back Bucket Seats
CBLP - Suede Door Trim Panel w/Map Pocket
CFMS - Rear Folding Seat
CFP - 3rd Row Seat
CGWS - Next Generation Front Air Bags**
CJTS - Seat Track Cover
CKAS - Carpets - Floor and Cargo Area
CKTS - Cargo Tie Down Loops
CLEP - Front & Rear Floor Mats
CSRS - Passenger Assist Handles
CUCP - Floor Console
CUNP - Overhead Console
CURS - Rear Compartment Storage Tray
DGB - All 4-Speed Automatic Transmissions
DGTS - 4-Spd. Automatic 46RE Transmission
DHAP - Lock-Up Torque Converter
DHC - Full-Time Transfer Case
DJLS - Front Axle
DMHP - 3.92 Axle Ratio
DRBP - Corporate 9.25 LD Rear Axle
DSA - Anti-Spin Differential Rear Axle
EAAC - All Engines
EML - 5.9L V8 MPI Engine
GBBS - Tinted Windshield Glass
GCBS - Front Door Tinted Glass
GEGS - Deep Tint Sunscreen Glass
GFAS - Rear Window Defroster
GMLS - Liftgate Door w/Fixed Glass
GNCP - Sun Visors w/Illum Vanity Mirrors
GNTP - Rear View Auto Dim Mirror
GT4 - Power 6 X 9 Mirrors, Fold-Away
GVBC - All Vehicles W/Power Mirrors
GXRP - Keyless Entry
HAAS - Air Conditioning
HBA - Rear Air Conditioning w/o Heater
HGAP - Hood Insulation
HGDP - Deluxe Insulation Group
JAYS - Instrument Cluster w/Tach
JBFS - Instrument Panel Black Bezel
JCBS - 120 MPH Primary Speedometer
JHAS - Var Intermittent Windshield Wipers
JHBS - Rear Window Wiper/Washer
JJAS - Cigar Lighter
JJBS - Dual Note Electric Horns
JJJP - 12V Auxiliary Power Outlet
JKBS - Inst Panel Mounted Hood Release
JPAP - Power Windows
JPBP - Power Locks
JPSP - Power 6-Way Driver Seat
K2WP - STRIPE/BADGE/MOLDING/COLOR
K5WP - STRIPE/BADGE/MOLDING/COLOR
LAAS - Ignition Time Delay Lamp
LACP - Illuminated Entry
LAFS - Key in Ign/Seat Belt Warning Buzzer
LAJS - Headlamps On Warning Chimes
LALS - Low Washer Fluid Warning Signal
LAMP - Door Ajar Warning Lamp
LANS - Decklid/Liftgate Ajar Warning Lamp
LBBP - Courtesy Lamps
LBCP - Glove Box Lamp
LBDP - Ash Tray Lamp
LCDP - Map/Dome Reading Lamps
LDAP - Underhood Lamp
LDGS - Liftgate Flood Lamps
LMBS - Halogen Headlamps
LNJP - Fog Lamps
LPSS - CHMSL Lamp
LSAP - Security Alarm
MBPS - Body Color Front Bumper
MDAP - Front License Plate Bracket
MFNP - Body Color Grille
MGAS - Ram's Head Badge
MHAS - Black Windshield Moldings
MLAP - Body Color Fascias
MUZP - SLT Badge
MU1S - LXi Badge
MWGS - Roof Rack
MWHS - Rear Wheelhouse Liners
NAA - Federal Emissions
NBHP - Emissions - High Altitude Tracking
NBKS - EVAP Control System
NF4S - 25 Gallon Fuel Tank
NHBP - Auxiliary Transmission Oil Cooler
NHFP - Power Steering Cooler
NHMP - Speed Control
NMCP - Heavy Duty Engine Cooling
PW7 - Bright White Clear Coat
QW7S - Bright White Clear Coat
RAAC - All Radio Equipped Vehicles
RAZP - AM/FM Cassette Compact Disc Radio
RCK - Infinity Speakers
RDDP - Fixed Long Mast Antenna
SBAS - Power Rack and Pinion Steering
SCGP - Leather Wrapped Steering Wheel
SFBS - Front Heavy Duty Shock Absorbers
SGBS - Rear Heavy Duty Shock Absorbers
SHAS - Front Stabilizer Bar
SHCS - Front and Rear Stabilizer Bars
SUAP - Tilt Steering Column
TBBS - Full Size Spare Tire
TBMS - Tire Carrier Winch
TUT - 31X10.5R15 OWL All Season Tires
TZAP - Goodyear Brand Tires
WJ9P - 15X8.0 Aluminum Wheels
WKBP - Matching Spare Wheel
XDXS - Scissor Type Jack
XEUS - Front Suspension Skid Plate
YAAS - Build To U S Market Specifications
YEP - Manuf Statement of Origin
YGFA - 8 Additional Gallons of Gas
ZACP - Spring - Left Front
ZARP - Spring - Left Rear
ZNCP - Spring - Right Front
ZNRP - Spring - Right Rear
Z5AS - GVW/Payload Rating
0NPA - No description found
1AAS - U.S. Dealer Retail
169S - Zone 69-Phoenix
2TFA - Customer Preferred Package 2TF
28F - Customer Preferred Package 28F
3VSA - Customer Preferred Discount
4EA - Sold Vehicle
645S - Utah State Code
945S - Utah State Code
Old Dec 15, 2010 | 10:32 PM
shrpshtr325
THE ULTI-MOD
yea i know the alternator question had come up before but i was at school at the time and didnot have the build sheet with me, if you were to check the color code on my truck i believe it would not show up under the 2002 model year, my truck was one of a few (50 i think) that was made in 2002 as a floor model to show off the 'new' color
