Help! what did I break????
Old Dec 16, 2010 | 04:27 AM
  #21
oklahomafbody's Avatar
oklahomafbody
A couple places I talked to did call people they know. A couple others gave me numbers to other salvage yards they deal with. No luck. I am really leaning towards just attempting the rebuild myself.
Old Dec 16, 2010 | 04:58 AM
  #22
oklahomafbody
Also, can anybody point me to a post, or maybe put up a list of the common replace items in most any rebuild other than frictions and seals(obvious stuff) Recommended upgrades for a daily driver that will tow occasionally, etc. Something I can make note of to take to the trans supply place to order parts all at once. Theres a lot of good info in the 46re tutorial, But I just cant keep track of all the recommened, needed, and if your building this or that you need to do this too, but not needed for daily and light towing use. Sorry if I confuse anybody, its 4am and Im running on little sleep already. This things gonna give me a stroke. Stuff that should be replaced even if it looks good still.
Old Dec 16, 2010 | 10:42 PM
  #23
oklahomafbody
Can anybody tell me the difference in this trans and one from a 98 Ram, same motor and 4x4?
Old Dec 16, 2010 | 10:51 PM
  #24
WhiteWidow00's Avatar
WhiteWidow00
What kind of ram? 1500, 2500, or 3500? The 5.9 360 was used in all 3.
Old Dec 16, 2010 | 11:59 PM
  #25
oklahomafbody
Listing only says it came from a 98 4x4 Ram with the 360. Why would the transmissions be different between those with the same engine and 4x4?
Old Dec 17, 2010 | 03:48 AM
  #26
coreybv's Avatar
coreybv
As the hauling and towing capacity goes up, so does the demand placed on the tranny.
Old Dec 17, 2010 | 06:57 AM
  #27
oklahomafbody
I was under the impression a 46RE's internals were all the same regaurdless of truck rating.... ?
Old Dec 17, 2010 | 08:50 AM
  #28
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if that the case im pretty sure you would never hear of these trucks blowing up the 46res
Old Dec 17, 2010 | 01:05 PM
  #29
coreybv's Avatar
coreybv
I suppose it's possible that they use the same tranny in all 3 models, but it wouldn't make much sense to me. You'd end up with models that had either an insufficient tranny, or unnecessary overkill (which == unnecessary expense)...
Old Dec 17, 2010 | 01:12 PM
  #30
WhiteWidow00
I would get ahold of the owner and ask what it came from exactly.
