Front Bump Stop..?
Old Dec 14, 2010 | 09:35 AM
woozer74's Avatar
woozer74
Default Front Bump Stop..?
Hello all.
I have a '03 DD 4.7L 4WD and I was looking underneath the front end just outta curiousity and noticed what I assumed to be a front suspension bump stop. I could be wrong, It looks like the rubber housing is all cracked in 2. Are these a DIY kinda thing? and how soon should I look into getting them replaced? Also, anyone have any ideas as to where I might be able to pick up replacements as well? Thanks in advance! :-D
Old Dec 14, 2010 | 09:40 AM
Dans01Durango's Avatar
Dans01Durango
They are called jounces. It's a dealer only part. They come in pairs and last I paid for them was $30. You can take out the old ones by using a long flathead and prying them out of the cup. Make sure you get all the little pieces out cause the new ones need a good seat to be effective. There are little indents around the cup but don't worry about them. Use a mild dishwashing detergent to lube the new jounces and slip them into the cups and you're done. Takes about 5-10 minutes. Hey, I noticed you have some sort of liquid all over your underside. Is that oil or just water?
Old Dec 14, 2010 | 10:55 AM
woozer74's Avatar
woozer74
Hey, thanks DD,..That's a bit of relief. Pretty quick fix job, then. There's a couple Dealerships around here, I can go to about the parts, that shouldn't be a problem. thanks for the tip(s), also. The "liquid" you're seeing, DD, is just wet from snow travel. We got a little bit of it in our area, (Eastern PA), and the white-ish ash stuff is of course, the salt from the roads. But that's all that is, just melted snow.
Old Dec 14, 2010 | 02:29 PM
tmartin72's Avatar
tmartin72
Just a little tidbit of info; when I found that my jounce bumpers were shot I noticed that they looked identical to the ones on my 1999 Chevy Tahoe. Sure enough, they were! They fit perfectly and have been working great for almost a year now.
Old Dec 14, 2010 | 03:56 PM
fcastro's Avatar
fcastro
There called "bump stops". Dealer only I ordered some for my 2000 durango few months ago. "Front Right/Left Bump Stops - 52106122AA" I am sure your part number will be different. Order them only cause the dealer marks everything up substantially.
Old Dec 14, 2010 | 04:31 PM
hydrashocker's Avatar
hydrashocker
Nice find!
Old Dec 15, 2010 | 10:19 AM
Dans01Durango
NP. Glad we could all help.
Old Jan 6, 2011 | 09:10 PM
ewr101's Avatar
ewr101
Question
I am looking replace the mangled front bump stops on my Durango as well and I found these at numerous places online. They look to be the same as the factory and, from what I see, would not be dealer-only. Am I right or wrong? Not starting anything, just want to know if I HAVE to go to the dealer for them.
http://www.dormanproducts.com/da-35057-905-205.aspx
Old Jan 6, 2011 | 09:20 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
when i replaced replaced mine 2.5 years ago the only place to get them was the dealer, the front and rear stops are different.
when i did mine the set of stops were not that bad from the dealer i believe i paid $30 from the dealer for them, i wouldnt waste time pondering if the online store has the correct part (that picture also doesnt look quite right to me), and that site not having a price listed throws up a red flag to me also
Old Jan 6, 2011 | 11:22 PM
hydrashocker
Search: https://dodgeforum.com/forum/1st-gen...bump-stop.html
