Axle seems a little too small ?
Old Dec 19, 2010 | 06:43 PM
cargod1's Avatar
cargod1
Default Axle seems a little too small ?
I recently changed my cv axle on the driver side on my 01 Durango, And an interesting clicking sound was noticed today, When I took off the tire to have a check I noticed the axle seemed to have pulled away from the spindle near the transaxle about an inch.
Any suggestions ???
Old Dec 19, 2010 | 10:58 PM
hydrashocker's Avatar
hydrashocker
Could be the incorrect CV half shaft. I think the right and left sides are different part numbers for that reason. Double check your part numbers.
Old Dec 20, 2010 | 09:14 PM
cargod1's Avatar
cargod1
Well it seemed reasonable, I mean parts can get mixed some times , so I got another one and put it on........ Clicking is still there .
this time I drove it around to be able to put a better explanation out here. This clicking is coming from the driver side front and is only heard when I accelorate. So I decieded to look elsewere , I noticed the Oil level was very very low.......
I added a couple quarts but clicking remains. Running out of ideas fast on this one !
Old Dec 20, 2010 | 09:40 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
did you check the trans fluid level? and the fluid level in the transfer case?? if either are low it can create odd sounds
Old Dec 21, 2010 | 09:20 AM
Dans01Durango's Avatar
Dans01Durango
Maybe a screw/nail stuck in the tire?...
Old Dec 22, 2010 | 02:58 PM
hydrashocker
Is the new CV fully seated correctly now?
Old Dec 23, 2010 | 10:41 AM
cargod1's Avatar
cargod1
Yes the Cv is fully seated it turned out I was sent the wrong one So I exchanged it and replaced. And I figured out what my clicking sound was..... driveshaft, from transfercase to transmission. Thanks for all your suggestions very helpful !!
Old Dec 26, 2010 | 11:38 PM
hydrashocker
Thank you for the update!
