OEM Drivetrain capability
Old Dec 22, 2010 | 09:17 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
heres your answer on fuel economy, if you are increasing the power from the engine the chances are that you will be useing more gas therefor getting fewer miles to the gallon, the most efficient setup w/o a custom tune is to leave it stock and put maybe a k&N drop in filter in the air box.
Old Dec 22, 2010 | 12:27 PM
Biff85ta's Avatar
Biff85ta
Originally Posted by MoparMan1991
no typos here, why do you disagree with my choice?
Most 235/85 are load rated for one ton trucks. I would just think they would be a little on the stiff side but it is your truck.
Old Dec 22, 2010 | 05:16 PM
hydrashocker's Avatar
hydrashocker
You can do a few great mod's and never have to worry about any of the drive train including T-case, Trans, and diff's.
Do a Home Brew CIA, K&N Drop in, TPS mod, and 3" cat back exhaust, and Champion Copper plugs and call it a day. If you feel that's not enough get a Super Chips, SCT, or Hypertech tuner.
Old Dec 22, 2010 | 07:13 PM
MoparMan1991's Avatar
MoparMan1991
Well they are aggressive A/T tires anyway, and I got them purposely for higher load ratings just because they have a deeper tread pattern which means the tread will last longer.
Old Dec 22, 2010 | 08:18 PM
MoparMan1991
What is this "Home Brew CAI"?
Old Dec 22, 2010 | 09:44 PM
WhiteWidow00's Avatar
WhiteWidow00
Home brew CAI:
https://dodgeforum.com/forum/1st-gen...m-air-diy.html
Old Dec 22, 2010 | 10:22 PM
MoparMan1991
seems a bit cheaper than an aftermarket system, but so i understand correctly, the hose comes out near the radiator to allow for maximum air intake, but is still covered by the bumper? In my D i dont have that kind of space under the hood.
Old Dec 22, 2010 | 10:31 PM
WhiteWidow00
No it comes out beside the radiator so the air flow from the grill is where the air is pulled from.
Old Dec 22, 2010 | 10:36 PM
MoparMan1991
well beside the radiator by the air box is this metal thing, im sure you know about what that is. can i squeeze the tube between that thing?
Old Dec 22, 2010 | 10:45 PM
WhiteWidow00
Sorry sent you to the wrong link. Sorry for your waste of time, however here is the instructions for the 4.7!
Originally Posted by Dans01Durango
Guess what? I had some time and I decided to install... a CAI!!!
Here are the pics:
New filter
Airbox connect. I used steel-wire reinforced plastic flex tubing with screw-type hose clamp to hold the tubing to the connector. Connector screwed into the airbox
How the tubing was routed
Closer view of route
CAI opening
Closer view of opening
Any comments? Yeah, I know the tubing is kinda thin at one point but I'm thinking venturi effect.
