OEM Drivetrain capability
Old Dec 21, 2010 | 08:34 PM
MoparMan1991's Avatar
MoparMan1991
Exclamation OEM Drivetrain capability
Hey everyone on DodgeForum.com hows it going? Since I have recently determined a few other minor issues with my 2001 Durango 4.7 4x4 I now would like to start dressing it up a little. I have already started with P235/85R16 Goodyear Wrangler Authority A/T tires, soon I plan to get the front windows tinted to match, install a nerf bar kit, CAI, maybe a pushbar/grille guard, get an exhaust system, and do a full synthetic fluid change. My oly concern is how much extra power can the t case, shaft, tranny, and differential handle before I need to stard upgrading those as well. Again I thank everyone in advance for all of their insight!
Old Dec 21, 2010 | 08:39 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you plan on just doing bolt-ons you will be fine, if you plan to tear into the engine and REALLY build it up(cams, rollers, bore out the pistons, port polish, put it all together) is where you are going to run into problems
Old Dec 21, 2010 | 08:42 PM
MoparMan1991
Well I have thought about adding a HP cam, what kind of gain would that give me?
Old Dec 21, 2010 | 08:46 PM
shrpshtr325
THE ULTI-MOD
you would not need to worry about the trans/t-case just doing cams im not sure how much power they actually add tho
Old Dec 21, 2010 | 08:52 PM
MoparMan1991
Okay so by only using bolt ons would it help or hurt my fuel economy, with more power comes less work as I see it.
Old Dec 21, 2010 | 11:12 PM
WhiteWidow00's Avatar
WhiteWidow00
Most bolt on's will help your fuel economy. If you're worried on power and increasing fuel economy I would recommend starting with a CAI because this gives the engine cold air which has more mass and keeps the engine cooler. I gained a nice fuel economy boost off of this.
Also, I would recommend getting a power programmer. This way you can gain some serious HP and also can use a fuel economy mode and this does help quite a bit as I use a SuperChips programmer.
Old Dec 21, 2010 | 11:13 PM
MoparMan1991
signature check
Old Dec 21, 2010 | 11:17 PM
MoparMan1991
its not working!
Old Dec 22, 2010 | 02:19 AM
Biff85ta's Avatar
Biff85ta
Please tell me this is a typo? You really meant 235/75r15?
Old Dec 22, 2010 | 06:59 AM
MoparMan1991
no typos here, why do you disagree with my choice?
