Infinity Speakers
Old Dec 29, 2010 | 09:52 PM
  #31
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the infinity series you are asking about are the replacements that most of us have used
Old Dec 29, 2010 | 10:00 PM
  #32
MoparMan1991's Avatar
MoparMan1991
Okay I finally get the answers I need, thank you guys. Now the question is: Does anyone know the power ratings of the factory amp?
Old Dec 30, 2010 | 09:11 PM
  #33
MoparMan1991
ive looked for hours and I cant find anything
Old Dec 30, 2010 | 10:47 PM
  #34
shrpshtr325
THE ULTI-MOD
get in touch with indydurango, or kensai, one of them are your best bet for answers
Old Dec 30, 2010 | 11:42 PM
  #35
MoparMan1991
Well I went and p1ssed Indydurango off because I called out his bad answer. I didn't mean to come off as a dick.
Old Dec 30, 2010 | 11:57 PM
  #36
Biff85ta's Avatar
Biff85ta
I did not firnd any info I would trust but I would say it is not very much. I also found the pinout for it in my search if you are thinking of bypassing it or replacing it.
12V DC Battery(Constant)Pink 1 15 Amp Junction block Switched AccessoryRed/white 18 10 Amp Junction block Ground Black Power Antenna NCA Illumination White Dimmer Orange Protected by fuse no. 9 of 5 amperes in junction block Steering Wheel Control Wire Gray/white Black/light green goes to ground. Violet/yellow for PCI busses Left Front + Dark green Line level output Left Front - Brown/red Line level output Right Front + Violet Line level output Right Front - Dk.blue/red Line level output Left Rear + Brown/yellow Line level output Left Rear - Brown/lt.blue Line level output Right Rear + Dk.blue/white Line level output Right Rear - Dk.blue/orange Line level output
AMPLIFIER OUTPUTS Wire FunctionColorNoteFuse #SizeLocation12V DC BatteryViolet Amplifier pins C1-1 & C1-2 13 15 Amp Junction block Remote Turn On (input) Dk.green/red Amplifier pin C2-4 Left Front Mid + Lt.green/violet Left Front Mid - Lt.green/dk.green Right Front Mid + Lt.blue/violet Right Front Mid - Lt.blue/black Left Rear Mid + White/red Left Rear Mid - White/black Right Rear Mid + Tan/violet Right Rear Mid - Tan/black
AT SPEAKERS Wire FunctionColorNoteLeft Front Tweeter + Lt.green/violet Left Front Tweeter - Lt.green/dk.green Right Front Mid + Light blue/red Right Front Tweeter + Lt.blue/red Right Front Tweeter - Lt.blue/black Left Rear Tweeter + White/red Left Rear Tweeter - White/black Right Rear Tweeter + Tan/violet Right Rear Tweeter - Tan/black
Old Dec 31, 2010 | 01:03 AM
  #37
hydrashocker's Avatar
hydrashocker
Look in here for part numbers that will interchange: https://dodgeforum.com/forum/1st-gen...wers-faqs.html
Old Dec 31, 2010 | 12:28 PM
  #38
Kensai's Avatar
Kensai
My thoughts on the speaker ohm ratings. Personally, I prefer 4 ohm over 2 ohm for these reasons:
Longevity of the amp and speakers. 4 ohm equipment operate cooler and provides less stress on the equipment vs 2 ohm if you frequently use your audio at moderate power levels.
4 ohm speakers provide much better sound clarity. That is why alot of the very expensive high end home audio equipment and speakers.
4 ohm equipment is easier and cheaper to find and replace vs 2 ohm equipment.
Old Dec 31, 2010 | 05:08 PM
  #39
MoparMan1991
Kensai - I got your message about the amp but I have no idea how to do anything with that stuff. Im trying to keep it simple by only having to replace the tweeter and some speaker seals.
Old Dec 31, 2010 | 05:09 PM
  #40
MoparMan1991
Oh and thanks Hydra for that link!
