neutral park switch wiring harness
Old Jan 22, 2011 | 02:56 PM
jmess's Avatar
jmess
Default neutral park switch wiring harness
does anybody know where i can get the wiring harness for the neutral park switch on a 98 5.9l? i went to the dealer and they were saying i was wrong about what i needed and insisted on the one one for the transmission speed sensor or something like that. so i cracked and paid 25 bucks for it, brought it home and then...SURPRISE!.....wrong harness. the one they gave me was 2 pronged and only had 2 wires going to it. the one i need is 3 pronged and has 3 wires. i called the dealer and explained the situation and they looked it up and said the part is unavailable from the dealer. so im stuck now. none of the local boneyards have durangos that are in the condition to take parts from (crushed already) does anybody know what else i could do?
Old Jan 22, 2011 | 04:48 PM
jmess's Avatar
jmess
also is there any special way to take the actual switch off of the tranny? i cant seem to get any sort of wrench around it because of the angle its at compared to all of the parts around it
Old Jan 22, 2011 | 05:52 PM
bjr1a's Avatar
bjr1a
Do you have the 46RE trans?....If so Yearone.com sells those connectors...its the same as vintage and collectible mopars... with 904 and 727 transmissions
Brian
Old Jan 22, 2011 | 05:53 PM
bjr1a's Avatar
bjr1a
Also that switch is removed from the 46RE with a 1 inch socket.....
Old Jan 22, 2011 | 06:11 PM
jmess's Avatar
jmess
im not sure what kind of transmission i have. ill take a look at the site and see if thats the right harness or not
Old Jan 22, 2011 | 06:22 PM
jmess's Avatar
jmess
i cant seem to find it. maybe im using the wrong search terms but it just isnt there for me. would you happen to have a link
Old Jan 22, 2011 | 07:08 PM
bjr1a's Avatar
bjr1a
http://yearone.com/serverfiles/fbsho...fety&SM=1&SC=1 ........
Old Jan 22, 2011 | 07:13 PM
jmess's Avatar
jmess
thanks but thats not it. after hours of scowering craigslist and i finially found a few d's that people are parting out about 45 minutes away so im gonna go see them this week ans see if i cant get this damn thing
Old Jan 22, 2011 | 08:11 PM
bjr1a's Avatar
bjr1a
are you sure your talking about the neutral switch?...because the connector is the same...you will simply have to buy the harness and cut the connector and splice it into your existing harness.....
Brian
Old Jan 22, 2011 | 08:18 PM
bjr1a's Avatar
bjr1a
why not make your own? go to http://www.pcsconnectors.com/delphi_terminals.aspx and look at the female weatherpack terminals....they are .13 cents apiece ....goodluck
Brian
