Check Valve In Trans. Cooler Line
I need to know if my 2000 Durango 5.9L 4x4, 46re trans. has a check valve in one of the cooler lines. I am rebuilding my trans. and have read if you have one make sure it is replaced or removed because they plug up and cause the trans. to fail. My truck does not have a tow package, so there is no external cooler. Thanks for reading.
im actually replacing my radiator in my 99 dakota 5.9 and the front radiator has two fixed lines how do i get them off or will my new one come with the whole assembly; the wierd thing is one of them runs from the front to the thermostat which is hooked to the ac line that runs into the ac compreser any ideas i can post pics if needed
Trending Topics
If you have a radiator that has the auxiliary transmission cooler and you get a replacement radiator with the same auxiliary transmission then the main steel lines come already on the replacement radiator and it will include a new trans cooler as well. Just get a new radiator in and look at it.
The A/C lines do not run into the radiator, they run to the condenser that is in front of the radiator. Yes there are 2 radiator looking things there......LOL
If you have a auxiliary trans cooler you will find it between the radiator and the condenser.
