Linkage disconnected from shifter???
Help Please!
2000 Dodge Durango 4x4
When shifting from 4WD to 2WD, it was giving me a little trouble but then suddenly popped free and is now a loose, floating shifter. While on a slight incline and in Park, the Durango will roll back. I'm guessing this means it was between 4WD and 2WD when it came loose and is still there. Now, I'll admit I don't know much about cars but I went underneath and found the arm that the shifter above is connected to. When I push or pull it, the shifter moves above. However, there is another little arm connected to this and that is connected to nothing.. so there's the problem right? My question: What does that connect to? I was hoping I could put it in to 2wd from under the car so I can at least move it. Then I can put it on some ramps and try to reconnect it.
I found a similar problem here: https://dodgeforum.com/forum/1st-gen...d-linkage.html BUT it doesn't say how to put it back in to 2WD and I'm not sure if this is my same issue.
Any help would be greatly appreciated. Thank you
That's what I'm hoping. My problem is I don't see where the arm connected to before it came loose so I don't know what to push (or the direction) to put it back in to 2WD. Would it need to be in neutral?
http://www.mediafire.com/?976yacub48f588t
this is the diagram from the factory service manual available for download in the FAQ thread at the top of the page, if 2wd is all the way forward then move the lever on the t-case all the way towards the rear of the vehicle. take a look at the diagram and you should be able to figure it out
Thanks again
Also, any ideas on how to get the part numbers for these bushings? I think I'm gonna try to do this myself
Trending Topics
idk about the part number for the bushings, but yes you seem to have the right idea on how to shift it manually, although you could also just pop the shift linkage back in, and have someone shift it from inside (or at least put the inside in 2wd so you can use the linkage to gauge where you need to stop)
N0, You will have to set the emergency brake and chock the wheels because it can roll.
By design it appears that the shifter should be all the way forward in the cab (2wd) and the linkage on the T-case should be all the way backward for 2wd.
Now you will need to find a new bushing. Most people find them in a junk yard as I think the bushing is out of production from the dealer. You could make a new
Polyurethane bushing but I have not yet done this however the meassurements are here: https://dodgeforum.com/forum/1st-gen...age-issue.html
