rear band adjustment 44re
What is the proper spec for the rear band adjustment on the 44re auto trans? Everything i have read is consistent with the 72-in lb, but then how far to back off the adjusting screw? My Haynes manual says to back off 4 turns, but the 44re service manual i found online claim to only back off 2 turns. Anyone know what is correct?
99 5.2L Durango 44re auto trans
I also find differing values for the front band adjustment, but 2 7/8" turns to 2 1/4" turns isnt near as huge as the difference for the rear. I am still questioning which is right for that as well but figured i would start with the rear band question as the difference is so large. Plus on the front I can/will use the method you mention about working in 8ths, but for the rear the pan has to be dropped so I'm hoping to get it right the first try.
The last time I talked to master tech I asked him on that, he stated that he adjusts the bands so there is between 1/4" to 1/2" loop of play between the band and the clutch. This could be why there are so many off posts about it. I asked him to take a picture of it next time he adjusted one for reforance but he most likely forgot. Regardless I would do what he tells us as he is a 20+ year OEM Transmission Master Tech and is over a lot of shops. Feel free to shoot him a PM.
Out of the 1998 service manual it states:
Rear Band:
Mopart ATF Plus 3, Type 7176 fluid.
Front Band:
42RE TRANSMISSION
(4) Lower vehicle.
Rear Band:
REAR BAND ADJUSTMENT
The transmission oil pan must be removed for
access to the rear band adjusting screw.
(1) Raise vehicle.
(2) Remove transmission oil pan and drain fluid.
(3) Loosen band adjusting screw locknut 5-6 turns-
(Fig. 252). Be sure adjusting screw turns freely in
lever.
(4) Tighten adjusting screw to 8 N·m (72 in. lbs.)
torque.
(1) Raise vehicle.
lever.
torque.
42/44RE TRANSMISSION
²
Back off adjusting screw 4 turns.
²
Hold adjusting screw in place and tighten locknut
to 34 N·m (25 ft. lbs.) torque.
(5) Position new gasket on oil pan and install pan
on transmission. Tighten pan bolts to 17 N·m (13 ft.
lbs.) torque.
(6) Lower vehicle and refill transmission with
lbs.) torque.
Front Band:
FRONT BAND ADJUSTMENT
The front (kickdown) band adjusting screw is
located on the left side of the transmission case
above the manual valve and throttle valve levers.
(1) Raise vehicle.
(2) Loosen band adjusting screw locknut (Fig. 250).
Then back locknut off 3-5 turns. Be sure adjusting
screw turns freely in case. Apply lubricant to screw
threads if necessary.
(3) Tighten band adjusting screw to 8 N·m (72 in.
lbs.) torque with Inch Pound Torque Wrench
C-3380-A, a 3-in. extension and 5/16 socket.
(1) Raise vehicle.
CAUTION: If Adapter C-3705 is needed to reach the
adjusting screw (Fig. 251), tighten the screw to only
5 N·m (47-50 in. lbs.) torque.
Fig. 248 Throttle Valve Cable Attachment —At
Engine
Fig. 249 Gearshift Cable Routing
Engine
42RE TRANSMISSION
²
Back off front band adjusting screw 3-5/8 turns.
²
Hold adjuster screw in position and tighten locknut
to 41 N·m (30 ft. lbs.) torque.
44RE TRANSMISSION
²
Back off front band adjusting screw 2-1/4 turns.
²
(4) Lower vehicle.
