Turn Signal Problems
Old Jul 4, 2011 | 03:31 PM
  #21
topdogcustoms's Avatar
topdogcustoms
Originally Posted by rbittmann
FIXED Thanks to everyone who responded!
Glad you got it fixed!!!!!!
Old Jul 5, 2011 | 12:05 PM
  #22
rbittmann's Avatar
rbittmann
Originally Posted by topdogcustoms
Well i guess my book is wrong it says a 2000 is in the fuse panel at the end of the drivers side dash and 02-03 are behind the fuse panel
Yeah, at Autozone we looked at the listing for the part and it said 1999 and earlier it's behind the fuse panel and 2000 and later its at the end of the drivers side dash.
Maybe I have a weird tweener? Who knows.
Old Jan 31, 2013 | 11:58 PM
  #23
David William Cobb's Avatar
David William Cobb
where does that flasher go. I'm having the same problem with my 2000 4x4 4.7 SLT. I bought the flasher block but can't see where to replace it. Looked in the fuse box on the driversside of the engine
Old Feb 1, 2013 | 12:38 AM
  #24
that_guy's Avatar
that_guy
way up under the dash on the backside of the fuse box, the stock one is green. You'll have to reach up from the drivers side footwell. You might be able to get to it easier if you pull the dash bezel off (you literally just pull it off) then unscrew the headlight switch, then you should be able to see it.
Old Feb 2, 2013 | 11:24 PM
  #25
David William Cobb
thank you so much for telling me it was the "green" block. That made it so much easier to replace
Old Feb 3, 2013 | 12:38 AM
  #26
that_guy's Avatar
that_guy
no problem
Old Feb 3, 2013 | 11:55 AM
  #27
Old_School's Avatar
Old_School
Just a FYI not all trucks have it in this location... mine is located in the front side of the fuse box just after you remove the cover. I believe my neighbors early 99 is also that way. IMHO, that's were it should be located on all the trucks, just wanted to point out that some are located in different places...
Old Feb 3, 2013 | 12:17 PM
  #28
that_guy's Avatar
that_guy
that's odd, mines an early 99 also (build date is nov. 98) and mine's up under the dash. It does make sense for it to be on the front of the fusebox rather than on the back.
