Magnum 360 Cam Suggestions?
Old 03-08-2011, 08:58 AM
Adobedude's Avatar
Adobedude
Adobedude is offline
Unhappy
Originally Posted by Sooper
I like it. I assume it will work with stock valve train? I will of course buy new springs to match the cam, and rebuild the heads with new hardware and seals. I just don't want to replace the rockers if I don't have to and at this point I am still up in the air on the larger valves.
For what you're doing stay with stock valve size, especially on stock Magnum heads, don't spend the money on them. They have a limited life span.
But....The stock two piece valves like to snap the heads off when you start increasing spring pressures.
Wimpy cam, valves, springs etc are never a problem on a stock motor, all the crappy parts Mopar put in the Magnum motor work in happy harmony until you change something...Then you have to change everything.
  #22
Old 03-08-2011, 09:42 AM
Sooper's Avatar
Sooper
Sooper is offline
Great advice. Is there a part number for valves that replace the stock valves but handle the higher spring pressure better? I like the idea of saving the money on the larger valves but I want all new hardware. If I can replace the stock valves with something a bit better then great.
  #23
Old 03-08-2011, 12:07 PM
01 6.3L RT's Avatar
01 6.3L RT
01 6.3L RT is offline
This isn`t the cam i`m running , but my custom cam builder said this will work very well with stock valvetrain with out a problem
  #24
Old 03-09-2011, 12:42 PM
Adobedude's Avatar
Adobedude
Any cam won't work with the stock springs, they can barely handle a stock cam, especially with some miles on them
  #25
Old 03-09-2011, 12:50 PM
Sooper's Avatar
Sooper
Sooper is offline
Got a part number for better valves that drop in to replace the stock valves with no mods?
Thanks.
  #26
Old 03-09-2011, 05:04 PM
Adobedude's Avatar
Adobedude
Thanks.
http://chucker54.stores.yahoo.net/valves3.html
1.92 intake P5249875
1.625 exhaust P5249876
Quick Reply: Magnum 360 Cam Suggestions?
