4WD question
#21
Basically what that does is a test of the cluster, I'm not sure if it will light up the 4WD lights or not since those are directly connected to the switch and just pass through the cluster. If you saw "chec" in the odometer and the needles move then it went into test mode. All of the red lights on the top row on the cluster are LEDs and won't burn out, but everything on the bottom row are actual light bulbs that can be taken out and replaced.
I went out to my Ram (which is a different cluster I know) and the 4WD light DID NOT light, however it works. Can someone check this to ensure the lights come on?
I tried holding down the trip button on the cluster then turning the key on but all that did was make hardly any of the dash lights go on?
