ABS troubles help
Old Mar 15, 2011 | 11:58 PM
Biged007's Avatar
Biged007
Default ABS troubles help
I have a problem with the abs system on my 2000 xlt the control went nuts sounds like a hyd. pump leaving me to unplug the thing or it will kill the battery Ideas please!!!!
Old Mar 17, 2011 | 03:30 PM
trrini's Avatar
trrini
Default Trrini
Yep. I have a similar problem on my 99 5.9 SLT (93 K). The ABS will engage at very slow speeds which increases the stopping distance. However the ABS light is not on. I had to unplug the wires from the ABS unit under the hood to disengage the ABS System. I remember reading somwhere that the ABS sensor on the front wheels could have accumulated a bit of rust and cleaning that should correct the problem. I've taken a look at the front wheel but could not see the sensor without removing the brakes (pads / Rotor). I had an earlier problem with the ABS light being on which was attributed to the rear ABS sensor, which I was able to change and that took care of the light. I gleaned that information from this site - invaluable information here. Thanks to all the Pros here!
Old Mar 17, 2011 | 11:48 PM
hydrashocker's Avatar
hydrashocker
It is either an open grounded sensor or a bad ABS Module.
Old Mar 17, 2011 | 11:58 PM
dcfox43's Avatar
dcfox43
Hi I have 2000 2d slt and I replaced my drums rotors,and brake pads but now i think it's my abs the light is not on. but when braking at fast speed i know abs holds and let's go and repeats but it does it once only in my truck and keeps going. what is the problem? a sensor?
Old Mar 18, 2011 | 01:09 PM
Evon Trizmo's Avatar
Evon Trizmo
When I slam on the brakes hard, the rear wheels always lockup while the fronts don't and the abs kicks in and says hey learn how to drive. So anyways consdering you just replaced your rotors they have more metal on them again which will make them a lot easier to lockup. If your rear has brake drag now with the new rotors, deffinetly get that adjusted as that will be your problem right there.
On another note, it could be your rear sensor too since you had the rear brakes all apart maybe it got dirty with a little grease on the sensor flywheel.
Old Mar 18, 2011 | 02:29 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the rear abs sensor is in the differential, not at the wheels
Old Mar 18, 2011 | 02:56 PM
WhiteWidow00's Avatar
WhiteWidow00
Yes there is a speed sensor by the wheels but ABS sensor is on the diff.
Old Mar 18, 2011 | 03:29 PM
dcfox43's Avatar
dcfox43
So I have to open the differential and find the abs and check if it needs a replacement?
Old Mar 18, 2011 | 03:35 PM
Evon Trizmo
Ah yes yes that's right the VSS is the rear abs sensor on these trucks also, forgot about that, at least on my 98 D, not sure about the newer models if they added more. So your rear brakes are probably biting more then your front when you hit the brakes causing the rear tires to lockup, which is easy to do because the front is where all the weight is. I'd start looking at adjusting your rear brakes to better match the front first.
Old Mar 18, 2011 | 04:20 PM
shrpshtr325
THE ULTI-MOD
you dont have to open the differential, the sensor sits on top of it, so you can pull it out the top of the diff to replace it/clean it
