Transmission trouble
Old Mar 26, 2011 | 02:54 PM
winkie74's Avatar
winkie74
Default Transmission trouble
okay so heres the problem im having occasionally while im accelerating (usually on the highway to around 60) my automatic tranny shifts from 1 to 2 gear fine but itll sometimes get stuck shifting from 2 to 3 and in order to get it to shift i either have to backway off on the throttle and reaccelerate or floor it. i did some research and i found that the governor solenoid in the tranny might be the problem but i would like to see what some of you guys think or if its happened to someone before. help would be very appreciated.
Old Mar 26, 2011 | 04:04 PM
WhiteWidow00's Avatar
WhiteWidow00
If you floor it and it shifts to 3rd gear, you got bad issues with your transmission. First what engine do you have in your vehicle. I can see you have a '99 but that means you either have a 5.2 or 5.9 (with either 44re or 46re transmission).
We need this information before helping any further.
Old Mar 26, 2011 | 04:22 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would start by checking the TV cable adjustment, thats what it was on my dads old dak when it did this
Old Mar 26, 2011 | 10:28 PM
hydrashocker's Avatar
hydrashocker
Cable adjustment and it also could be a 3-4 shift solenoid as well as your trans could need adjustment or incorrect fluid.
Old Mar 27, 2011 | 07:30 AM
White Buffalo's Avatar
White Buffalo
I had the same problem with my 98 Durango. I bought one bottle of Lucas Transmission Fix and did an oil change on the tranny using it. Worked great.
Old Mar 27, 2011 | 11:22 AM
WhiteWidow00
I have a feeling getting new fluid in the transmission pan did more than the treatment did...
Old Mar 27, 2011 | 12:34 PM
shrpshtr325
THE ULTI-MOD
i agree with widow, i would NEVER put anything in the transmission except ATF+4
Old Mar 27, 2011 | 02:05 PM
WhiteWidow00
I second that. The transmission is much too crucial and expensive to be worrying about getting a bad batch of treatment or something. I'm just not willing to make a $2,500 mistake because the bottle said it would work.
Old Mar 27, 2011 | 03:05 PM
Old_School's Avatar
Old_School
I would have to agree with the group.. i really never use additives and even when im 100% sure its okay i still am a little nervous about it..
Old Mar 27, 2011 | 03:10 PM
Old_School's Avatar
Old_School
I really get a kick out of that one they advertise on TV where they say it can take your ready to blow engine and turn in into a next to new running engine by pouring this stuff in the engine oil...
