Transmission Problem
Old Apr 21, 2011 | 01:08 PM
  #21
Chivas1's Avatar
Chivas1
after driving it a little longer, it still doing it but not as often. I will check fluid again. Do you recommend changing filter & fluid? I was told the transmission speed sensor could also be causing this, does that sound right?
Old Apr 21, 2011 | 02:26 PM
  #22
WhiteWidow00's Avatar
WhiteWidow00
I try to always change the filter when I change the fluid and yes I'd probably get some nice clean ATF +4 in the system just to make sure. I wouldn't think the speed sensor would cause it to throw a Gov pressure code because the speed sensor is linked in the ABS system to throw an ABS light.
Old Apr 21, 2011 | 11:58 PM
  #23
oklahomafbody's Avatar
oklahomafbody
Speed sensor will also affect shifting, but will usually throw a code. Causes late shifting and harsh engagement.
Old Apr 22, 2011 | 12:05 PM
  #24
Chivas1's Avatar
Chivas1
I just noticed it was leaking the Transmission Fluid yesterday, I am planning on changing the fluid along with filter this weekend & fixing the leak. Anyone know where it might be leaking from?
Old Apr 22, 2011 | 06:18 PM
  #25
rob[GL]'s Avatar
rob[GL]
Your best bet is to crawl under the beast and have a look... It's not like it's a slammed honda civic or something... It would take 30 seconds to peek at the leak. Really it could be coming from anywhere - asking us is like asking a psychic!
Seriously though, it could be from the transmission cooler lines, or the transmission itself... Who knows?!
I was under mine today and noticed that I've got a small leak on the drivers side... the transmission pan gasket probably needs to be replaced. And by "small leak" I mean I mean small... It wasn't enough to cause concern, no dripping or anything like that, just a little damp down the side of the pan.
Old Apr 22, 2011 | 07:05 PM
  #26
WhiteWidow00
+1 rob, also never use any kind of transmission stop leak of any kind. I don't even know if they make them but that would cause major problems if they do and although it seems like an easy way out, it's not.
Old Apr 25, 2011 | 04:32 PM
  #27
Chivas1's Avatar
Chivas1
It leaks from the front by the transmission mount, I checked the fluid again & it looks like I put too much when I added the 3 quarts. I will be changing the fluid so that I can get the correct amount in the transmission but also looking to change the solenoid & sensor. I read on here that someone found them both for about $110? does anyone know where I can find them for that price? Autozone has the solenoid for $120.
thanks
*I just found Transmissionpartsusa website which offers the solenoid & sensor for $100 shipped. Can anyone tell me what type of Transmission my 1999 Dodge Durango SLT 2WD has.
Thanks
Old May 13, 2011 | 01:15 PM
  #28
Chivas1's Avatar
Chivas1
I will be changing my Transmission Fluid this weekend & would like to know how many quarts to buy, I read that you need 10, but also saw 4!
Can anyone tell me how many quarts I will need if I will be doing a simple fluid/filter change?
Thanks
Old May 13, 2011 | 07:26 PM
  #29
dolittle's Avatar
dolittle
4 is probably close but I'd buy 6 just to be safe.
When I do my filter and band adjustments I buy 6.
edit. Put 4 in and warm up the transmission and check the fluid.
Old May 14, 2011 | 01:25 PM
  #30
hydrashocker's Avatar
hydrashocker
You should have the 46RE transmission.
Pick up at least 6-8 quarts for a simple trans fluid filter change. If you drop the valve body I would get at 8 for sure.
There is also band adjustments in that transmission, if you are uncomfortable adjusting the trans you can take your fluid/filter to a shop and have them do it for you for labor costs. You need to ensure they use YOUR fluid ATF+4, I like Valvoline Fully Synthetic in the blue bottle.
