Loud Fuel Pump?
2000 Durango SLT 5.9 w/ 3.55's
My fuel pump is quite loud... Inside the vehicle and out. It's just a constant "whirrrrr" sound. I can obviously hear it a lot better when I'm standing beside the while while it's running... But I can hear it a bit inside the vehicle as well...
Is this normal?
Should I make a quick video with my phone and upload it?
-rob
Is this normal?
-rob
is this only when your first turn the key on?
does it stop making noise after a couple of seconds?
can you hear it over the engine while driving?
i CAN hear mine prime up when i first turn the key to the 'on' position from inside the truck but it goes off after a few seconds and then i turn the key to start and i drive away.
The noise the fuel pump makes when you first turn the ignition to the on-position... which is like 3 seconds of priming... I know we're talking about the same noise.
Well... When the truck is running, it makes that same noise, but constatly all the time.
iv never noticed it while the engine is running, the pump does run while the engine is on but iv never heard it on mine, next time im home (ill be home this coming weekend) ill try to take note of if i hear it or not for you.
i cant hear mine with the engine running but my brothers did the same thing yours is doing and the fuel pump went out when i talked to my friend that works for dodge he told me if you start hearing the fuel pump all the time its on the way out
Trending Topics
That's definitely not normal. Unfortunately the fuel pump is in the tank so looks like you'll be dropping the tank soon. It too sounds to me like it's on it's way out, unfortunately.
